Question about Cell Phones
Turning on bluetooth - Cell Phones
Posted by Tony corkery on
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Mar 01, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Bluetooth turning on and off
Do you have a power saver setting on that might be turning it off? I'd say check that out first.
Jan 09, 2014 | Audio Players & Recorders
I can't connect my Iphone 5 to my bluetooth headset.
Did you put the bluetooth device in pairing mode? That way it is discoverable. Go to the bluetooth screen on the iPhone. Do you see the device listed there?
Jan 19, 2013 | Apple iPhone Cell Phones
How to connect Microsoft Bluetooth mouse 5000
Please refer to the below KB article, this will help you.
http://support.microsoft.com/kb/952818
Please rate if you like..Thanks
Aug 20, 2011 | Acer Aspire One AOD150-1920 Netbook
When turning bluetooth on light stays on and will not work properly
When turning the bluetooth on if you hold it too long it will go into the pairing mode (blue light on full time). You should only have to hold the button for 2-3 seconds or until you hear the first beep in the ear.
Jan 09, 2011 | Jabra Bluetooth Headset with Adjustable...
Bluetoothing
The only thing that I can suggest to to make sure that your bluetooth is not only switched on in the bluetooth settings but is also set to visable. If it is not then other phones will not be able to detect yours.
Nov 23, 2008 | LG Shine KE970 Cellular Phone
Bluetooth connectivity
Bluetooth doesn't shut off on its own unless you turn off your phone. In the bluetooth options, you should be able to select "Turning Bluetooth On", "Turning Bluetooth Off", or "Using Discovery Mode (60 seconds)." Discovery Mode, which I believe is what your using, is only used when connecting to another device. My question for you is, what kind of device are you trying to connect to?
Sep 05, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
