Question about Hayward Pool & Spa
Hayward h100id troubleshooting
I have a Hayward h100id pool heater. It is 5 years old. Recently it heats poorly. The burner comes on, the fan comes on, but the water seems to heat about 40%. The burner and fan continue to run, but the water barely heats when I feel it entering the pool. It also smells like the natural gas is not fully burning? Where do I start to troubleshoot?
Posted by Rick Muller on
1 Related Answer
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: Pool Heater. Hayward H100ID Starts fine
It sounds like your pool heater is not firing. I would check several things: the burner might be blocked and clogged, the gas valve might need to be replaced, the direct spark module might be malfunctioning, or the combustion blower might be cleaned. One of these is probably the issue. A service man can repair all of these problems.
Posted on Aug 19, 2010
Hayward pool heater H100ID troubleshooting
troubleshooting is possible on this unit. specific questions will get better answers
Jun 17, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a hayward H100ID above ground pool heater. Recently the heater is making a rattling sound and the in and out hoses are bucking or pulsating. The water is still being heated but somehting does not...
low water flow is making the heater knock, (PULSATE) clean filter or backwash, check pump and skimmer baskets and empty. if still low flow and knocking, check impeller on pool pump to make sure it isnt clogged.
Aug 30, 2011 | Hayward Pool & Spa
Pool Heater. Hayward H100ID Starts fine and heats for about 5 minutes. Then heat stops. You can feel the blower its just cold air.
Aug 08, 2010 | Hayward 100kbtu Pool Or Spa Propane Gas...
Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Pool & Spa Logo
122 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
