Question about Frigidaire Kitchen Ranges
How to light the pilot light on a frigidaire gas stove.
Posted by Donna Anne Callaghan on
5 Related Answers
SolutionGuy
Tracy Farrell
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Posted on Oct 29, 2008
Anonymous
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Posted on Feb 24, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Oven won't turn on, but the stove is fine!
Replace the oven glow bar ignitor.
Posted on Apr 20, 2009
Is there a pilot lite I need to light for my stove ffgf3011lw
Some stoves have pilot lights, some have an electronic igniters. If you hear a click, click, click when you turn on the gas, you have igniters.
Dec 06, 2014 | Frigidaire 30" Freestanding Gas Range -...
I have a gas stove/oven, when I turn on the oven the pilot light comes on but the burners don't ignite to heat up the oven. was told that is was not the element if I have a pilot light ????
Heater elements are found in electric ovens, you have a gas oven. It sounds like your main gas valve is not opening because the pilot would light it if it was open. It could be the gas valve itself of the flame sensor. Best to get a tech on it.
Jan 28, 2014 | Frigidaire FGF337BC Gas Kitchen Range
I just got a new tank of gas, is there a pilot light that i need to light
If you turn the dial to lite (stove top), and you hear a clicking... it is a piezo ignition system (no pilot).
Nov 02, 2013 | Frigidaire FGF326AS Gas Kitchen Range
How do you relight the gas stove.
not knowing the year ,, there are 2 ways stoves light, pilot light and glow plugs, following the gas line into the oven itself, If it has a pilot light you will see the control for it,, just hold a match or flame to the end of it and you should see a button to push,, If you have a glow plug,, it should light after a few second of turning on the knob,, watch to see if there is a glow next to the oven burner if there is and its not lighting,, your thermo coupling may be bad
May 30, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove pilot light is out
To light the pilot(s) you need to lift the top of the range up and use a lighter with the long spout to light the pilot lights that are located midway on each side between the burners. Once the pilots are lit then replace the cover to it's original position and the burners will ight when you turn them on.
Heatman101
Jan 24, 2010 | Frigidaire Kitchen Ranges
Pilot light
It was an electric ignition
Thank you
Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
293 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
