Question about Cameras
GOT LHT2436 TODAY THRU AMAZON AND THE CHARGER BLINKS RED WITH NO BATTERY IN IT AND DOES NOT CHANGE WITH THE BATTERY IN IT - DW SMITH 5206259461 [email protected] THANKS
Posted by DW SMITH on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Can't turn on and a battery sign with a red slush appears
Thee battery is fully discharged. It may take an hour on the charger before this goes away.
Posted on Mar 13, 2009
rycgl
Roy Cagle
  • 1545 Answers
SOURCE: charger light blinks red never
Worx has had issues with their chargers and their batteries. They don't seem to last as long as the machine does. A simple voltmeter test of the charger and any battery will tell the story. The charger's output rating should be printed on it and the battery also. Touch test leads from voltmeter to the two and check.
Posted on Oct 31, 2010
spyroshima
Spyro Matiatos
  • 210 Answers
SOURCE: on a 2000 ford explorer
Its a warning light that tells u if the OD is on or if it blinks there is a problem. Could be low fluid or... Have it looked at
Posted on Jan 10, 2011
Anonymous
SOURCE: fuji battery charger BC-45 -
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Posted on Jun 23, 2011
Anonymous
  • 300 Answers
SOURCE: camera will not come on
When the charger blinks it indicates is either charging or trying to charge.
A solid red light indicates a bad battery.
Posted on Jun 30, 2011
V6 Red light blinks 32 times
Your Dyson may not have been connected to the charger correctly when last put away.
Is it recommended to replace battery after so many years? I have had it for 5 yrs.
log onto amazon.com next to search bar is Your Account. Move pointer to bring up list. Click your account from list. On next page, right side is help desk home. click and fill in info on your problem. They can give you info on what type of battery and how to replace; they will answer back by emial or phone. Your choice.
3answers
Kindle Fire Will not charge
you might want to consider posting your question in a fan based support forum such as this one:
Amazon Kindle Fire Forum on XDA Developers
Have a Magical Day
K
My battery charger , olympus LI-40C blinks red and does not charge battery
Buy an el-cheepo battery charger kit and charge the batteries.
the olymup charger doesn't like non genuine batteries.
1helpful
My Black and Decker Firestorm 24 volt charger is not working
change batteries, your charger should indicate wheather you battery is good or noot on the pause inbetween blinks.
1helpful
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
