I need to reset my tushiba tv
I accidently changed the channel on my tushiba remote intead of my rogers remote
Posted by mahnaz on
5 Related Answers
jc8952
  • 4 Answers
SOURCE: channel keeps changing
I had the same problem and eventually found the solution. the tact switches behind the front panel buttons tend to leak when they get old causing them to activate by themselves. take off the back cover and the switches are mounted on a small circuit board that just clips in. remove the channel up and down switches from the board and clip it back in. your TV should work fine again. you of course will have no control with the front panel buttons but the remote will still work.
Posted on Oct 04, 2008
Anonymous
SOURCE: Skipped channel 4
I have the EWF2004 emerson TV. I tried a ONE For all universal remote and programmed it for a FUNAI TV code 0179 and it worked!!!!!!
Posted on Oct 05, 2008
Andrew Perrong
  • 285 Answers
SOURCE: I can't change the channels on the tv with remote or on tv contro
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
Posted on Jul 03, 2009
romsky79
rommel dadulla
  • 822 Answers
SOURCE: I accidently changed channels on top of sylvania tv and
pls autoprogram or add manually the channel lost.
Posted on Aug 02, 2009
Jim Franks
  • 374 Answers
SOURCE: Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Posted on Jan 11, 2010
My tv remote is not working inasmuch as I am unable to change channels. Tv is on BBC 1 and that is all I can watch
You go buy a universal remote and test your patience by typing in each of several codes for you TV until you find one that works. Some TV sets or attached boxes allow cable changing manually. Others do not.
But before you do that, make sure you have pressed either CABLE or TV at the top of your remote. You possibly have accidently pressed a button to control the DVD or some accessory device, rendering the remote unable to control the TV.
I might try to "autotune" the TV, i. e. preset the setup menu that causes it to search for the channels which the TV can receive. Something possibly may have happened in that realm.
And, you might even call your cable provider and ask them to reset your cable connection. You see, the problem might not be in the TV or the remote.
Good luck.
Aug 08, 2017 | Televison & Video
Have an Element TV and the remote will shut the TV off and on plus do the SAT/CAB Directv I can turn on and off but the channels won't gel so I can watch The TV
Search Results
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code. ... All the steps you'll need to program your Rogers Remote to control all your home theatre devices. .... the Cable turns on and off and volume etc. but will not shut offthe tv. ..... I bought a Element Electronic Smart TV and have set it up.
    Support ' Element Electronics - Elementelectronics.com
    www.elementelectronics.com/support/
    Element ElectronicsA description for this result is not available because of this site's robots.txt - learn more.
    DIRECTV - Support: Your Remote Control
    www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
    DirecTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On until they ... Power Key - Your DIRECTV™ Remote can operate alternate devices.
    [PDF]Get to know your remote control Need more help ... - AT&T
Jan 31, 2016 | RCA Televison & Video
I accidently changed my tv channel i have dish how do i get my dish back
Meshell Coles,
I would be happy to help get this fixed! If the TV is connected via a Coax cable, try changing it to 3 or 4 if TV1. If it is TV2 try 60 or 73. If the receiver is connected via a RCA (Red, Yellow, White) cable, HDMI cable, or Component (YPbPr), make sure the receiver is on the correct input.
If you have any other questions, just let me know!
Tommy Faust
DISH Social Media Representative
Sep 02, 2012 | DISH Network Televison & Video
Need the code to tune my remote to my tushiba tv model number rch7y46 4 in 1 remote
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141 0156
Apr 08, 2012 | Televison & Video
Code numbers for a Tushiba tv
try these three digit codes.018.045.128.141.369.379.
Feb 25, 2010 | One For All URC4220 Remote Control
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
Taper proof button was accidently set on the remote..cant shut t.v off..change channels, turn volume up or down. please help
We really need the model number of your tv (or remote if the remote didn't come with the tv) to help the best.
Are you sure there IS a tamper proof button?
You could try removing the batteries from the remote and at the same time, unplug the tv for a while. This may reset everything.
NOTE: If this answers your question, PLEASE GIVE ME A GOOD RATING! Thanks!
Mar 16, 2009 | Televison & Video
Remote only advances by one channel.
The button on the remote next to 0 and below 9 has to be depressed to _ _ before you select any 2 digit channels. I had the same problem and accidently figured it out. Hope it helps. TC
Jul 13, 2008 | Memorex MT2206 TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
