Question about Cuisinart Kitchen Appliances - Others
Replaced the pressure limit valve on Cuisinart electric pressure cooker CPC-600 it appears very loose sitting on the cover could the pressure blow the limit valve off the cover
Posted by tom_blackmon on
1 Related Answer
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: Need to see Manual for Cuisinart CPC 600 Pressure Cooker
Search the internet for:
Make + Model + the word "Manual"
or contact manufacturer support.
Posted on Apr 12, 2016
How to set the minutes to cook on a Cuisinart 600 pressure cooker
Hello, Andi -
From your question I can only guess that you do not have the instruction manual for the pressure cooker.
You can find the manual for the CPC-600 Cuisinart pressure cooker through the Cuisinart home page:
https://www.cuisinart.com/
Click or tap on Search. Enter the words "pressure cooker" (no quotation marks) in the Search box and click or tap on the magnifying glass icon.
The first pressure cooker listed in the search results will be the one you want (the CPC-600.) Choose that.
You will be brought to a description of your pressure cooker model. On that page, above the text describing the pressure cooker, you should see a link for Manual. Click or tap on that.
The PDF document for the Instruction Booklet will come up. You can download and save the instructions so you can have it for future reference and so you can print it. You will need Adobe Acrobat Reader software (free.) When you save the PDF file to your Documents folder, be sure to give it a name you can find again - maybe: Cuisinart CPC-600 Pressure Cooker Manual.
Be sure to read through the manual before using the pressure cooker. The Operating Instructions begin on Page 5.
Best wishes.
Mar 08, 2018 | Cuisinart Kitchen Appliances - Others
Apr 12, 2016 | Cuisinart Kitchen Appliances - Others
Why is my pressure cooker not running the length of time set?
You probably need to push set again or something when it appears you should be done. I have a slow cooker and they work that way. It appears to be running but you still need to push one more button or the program will stop after 15 minutes.
Sep 21, 2014 | Cuisinart CPC-600 6 Quart Electric...
Need a manual formodel epc660d pressure cooker
Can you tell us what the brand name is? I believe you're talking about a Cuisinart but they don't make a 660, they make a 600. If you come back and tell us the brand name I may be able to help more.
In the meantime, take a look at this manual and see if looks like your cooker:
http://www.hippressurecooking.com/cuisinart-electric-pressure-cooker-manual-cpc-600/
Nov 06, 2013 | Crock Pots & Slow Cookers
Need manual for Cuisinart
The manual for the Cuisinart CPC-600 6-Qt (5.7L) Electric Pressure Cooker can be downloaded from the following link:
http://www.cuisinart.com/share/pdf/manuals/cpc-600.pdf
This is the commonly available manual for the Cuisinart pressure cooker. Do you have a different model? Can you provide the model number to enable a more detailed search?
Jun 10, 2012 | Cuisinart 6 qt. Pressure Cooker
Lost instruction manual for Cuisinart cpc 600 require replacement!!!
The Instruction Booklet & Recipe for the Cuisinart Electric Pressure Cooker CPC600C series can be found online here:
http://www.cuisinart.ca/pdf/ibs/en/CPC-600C_en.pdf
Thank you for using FixYa!
Jul 11, 2011 | Cuisinart Electric Pressure Cooker CPC600
Kitchen Appliances - Others Logo
126 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
ThaMp3Doctor
ThaMp3Doctor
Irene Tulloch
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
