Question about Dirt Devil Vacuums
SOURCE: dirt devil vacuum belt
on the bottom of vacuum ther are 4 screws take them out then a cover should expose the roller the belt is right there
Posted on Jan 23, 2008
SOURCE: Dirt Devil M084600 Dynamite
Your roller won't turn. The belt is designed to break if anything threatens to keep the motor from turning. When you have the roller out, check the end caps to see if they rotate easily. If they do, then install a new belt being very careful that the belt is not pinched on the channel that it sits in. Once you have the belt installed, turn the roller by hand to make sure that there is no jamming or catching of anything. Install the plate and check the rotation again. Once you are satisfied that the roller turns easily, try the machine.
If the caps on the roller are jammed, as they will get from debris, hair and thread, etc., then you may have to replace the roller. The end caps on most of the Dirt Devils are carbon fibre and will break when you try to remove them.
Posted on Jan 31, 2008
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
SOURCE: Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 24, 2009
SOURCE: How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
Posted on Mar 08, 2010
Jul 14, 2017 | Dirt Devil Vacuums
Jun 27, 2010 | Dirt Devil Classic M08100 Bagged Handheld...
Mar 20, 2010 | Dirt Devil M084000 RoomMate Upright Vacuum
Nov 25, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Nov 25, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Nov 23, 2009 | Vacuums
Nov 06, 2009 | Vacuums
Oct 22, 2009 | Dirt Devil Vacuums
Oct 19, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Oct 12, 2009 | Dirt Devil Built-in Vacuum Systems Bagged...
155 people viewed this question
