Sanyo ASW-G185SB washing mashine E4 - Washing Machines
Posted by Kay Firstlady on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Posted on Oct 11, 2009
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
kapishtech
raj somaiya
  • 2272 Answers
SOURCE: my sanyo washing machine does
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
Narseman
  • 1082 Answers
SOURCE: Would you have a user
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
SANYO Owner ManualsTo find an Owner Manual for a SANYO product, enter the model # of the product below.
Please Note: We are in the process of upgrading the Owner Manual search to also include discontinued product documents. Please check back in a week or two if you need an Owner Manual for an older SANYO Product.
Model # ASW-F6OAT
Search Results
Sorry, could not find any documents that match your search criteria
Posted on Feb 21, 2011
john_cross
  • 6277 Answers
SOURCE: my washing machine is SANYO
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 22, 2011
liveone15
  • 61 Answers
SOURCE: my washing machine wont spin
Sounds like the belt broke on your washer.
Easy to replace and not that expensive.
Posted on Mar 09, 2015
My sanyo asw-180q error code E4. How can ifix it?
go to the manufactures website and download the user manual and look in the trouble shooting guide the download is usually free eric
Dec 31, 2017 | Washing Machines
Sanyo asw 70st washing machine makes lot of nose while spinning
Can any one provide me the Instruction manual for Sanyo #ASW-70ST?
Feb 23, 2017 | Washing Machines
How to open child lock on sanyo asw-a85ht washing machine
Apr 07, 2012 | Cars & Trucks
Would you have a user manaual for a Sanyo ASW-F6OAT washing machine? [email protected]
Model # ASW-F6OAT
Search Results
Feb 21, 2011 | Washing Machines
My washing machine is SANYO ASW-90WRTP. showes E4 on the screen. I guess it means Error 4, but I don't know how to solve the problem. Thanks.
Oct 11, 2009 | Washing Machines
The washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Dec 19, 2008 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
