Question about Cell Phones
Redmi note 4 sound via speaker but not to bluetooth paired devices. I did work but some setting not enabled
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: my blackberry bold does not recieve data via bluetooth
I think you read wrong praky, capt said already paired. The correct solution would be as follows:
1. Open the Media app.
2. Select a media type (e.g. Music)
3. Press Menu.
4. Select Receive Using Bluetooth.
5. Select Yes. (It will then ask you the location you want to save to but of course by default it will select the proper folder)
6. Select Save. (Transfer will begin
Posted on Mar 08, 2009
Anonymous
SOURCE: I can't receive files via bluetooth on my Blackberry Bold
When you want to receive a bluetooth file do the following:
1. Go to Media.
2. Hit the menu key (left of trackball) and select Explore.
3. Browse to the folder you want to store the file in.
5. Hit Menu key again and select "receive using bluetooth."
6. Send from the other phone.
You'll have to do this for each file individually.
Posted on Jul 10, 2009
Anonymous
SOURCE: bluetooth does not enable
Throw it as hard as you can !!!!!! It won't solve the problem,but it will sure make you feel better !!!!!! I am about to receive my 3rd 8220 Pearl !!!!! Pearl my ***.....Piece of **** is what it should be Called.
Posted on Nov 05, 2009
Anonymous
SOURCE: my model is xperia u20I...
you need to download an application called bluetooth file transfer from the android market. it will help you with the file transfer via bluetooth
Posted on Sep 06, 2010
Anonymous
  • 33 Answers
SOURCE: my new iphone 4 doesnt
According to the technicians of Apple, Bluetooth in iPhone does NOT recognize other iPhones/iPods/other brands of phones, because this facility in iPhone is not meant for transfer of data from one phone to the other. It is only for call-hearing and music-listening without keeping the phone attached to the ear.
Posted on Oct 16, 2010
Why cant i get my computer to dicover my auvio pbt200 bluetooth speaker?
  1. Try playing other audio files. Ensure that audio can play fine from the same audio device when using a headphone.
  2. If Step 1 is not the case, try listening to audio by connecting the speaker to the Bluetooth device using the Aux-in cable. This will isolate if it's a Bluetooth connection issue or not. Remember to disconnect/un-pair the Bluetooth connection first.
  3. If the issue only happens when connecting via Bluetooth, do the following:
    1. Adjust the distance between the speaker and the Bluetooth device.
    2. Reset the speaker to its factory default settings. For instructions on how to reset your speaker, go to the product's support site to view the relevant knowledgebase article.
    3. Clear the current pairing entry from your Bluetooth device. For instructions on how to clear the pairing entries, consult the user's manual of your Bluetooth device.
    4. Try re-pairing the speaker and the Bluetooth device. For instructions on how to pair the speaker with the Bluetooth device, go to the product's support site to view the relevant knowledgebase article.
    5. To further isolate, try pairing the speaker with other Bluetooth device.
  4. If the issue happens when connecting either on Bluetooth or Aux-in, please contact Creative Customer Support via email.
Note: Creative Bluetooth speakers do not need any driver to operate. You may need to update the Bluetooth driver of your computer's built-in Bluetooth adapter or your USB dongle. To determine whether your computer or USB dongle is updated with the latest Bluetooth driver, please refer to their user's guide or website for information.
http://support.creative.com/kb/ShowArticle.aspx?sid=90429
Jun 05, 2015 | AUVIO Bluetooth Portable Speaker
I have a portable wireless speaker model AWSBT7 will not go into the connect mode when pressing the button to sync up device I do not get the two beeps or the light does not flash faster
Hi Jerry, Are you using this method to pair your device?
Pairing
The Bluetooth-enabled device that you wish to stream audio to your speaker system must
fi rst be paired to the speaker. The process is simple, and in most cases the pairing process
needs to be done only once.
To pair your Bluetooth-enabled device with the speaker:
1. Make sure your device's Bluetooth is turned on. See the wireless and/or network settings
menu on your device to check.
2. If the speaker isn't already on, press the On-Off button to turn it on. You will hear a beep
to indicate the speaker is turned on. The indicator light on the back of the speaker starts
fl ashing blue.
3. Press and hold for 3 seconds the Pair button to enter pairing mode. You will hear 2 beeps
to indicate pairing mode is entered. The indicator on the back of the speaker starts blinking
faster.
4. Open the Bluetooth settings menu on your device. Select "AR SPEAKER" from the list of
devices available (you might have to scan for devices). If your device asks for a password,
enter "0000".
5. A confirmation screen will appear on your device once the speaker and the device are
successfully paired. The blue indicator turns solid blue to indicate successful connection.
The speaker is now ready for you to stream audio from your device.
Oct 24, 2014 | Audio Players & Recorders
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 | Cell Phones
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Apr 13, 2013 | Apple Soundlogic Itower Speaker Works W/...
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to setup bluetooth external speaker on Dell Studio 17 laptop
Ensure Bluetooth is installed and on in the notebook, then turn on the Bluetooth speakers, they should be detected by the system, then pair the devices in bluetooth manager.
Sep 13, 2009 | Dell Studio 17 Laptop
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
