Question about Asko Washing Machines
Asko stays in normal wash on timer - Asko Washing Machines
Posted by Alban Schmidtbauer on
Tom Chichester
    Top Expert:
  • Asko Master
  • 57,442 Answers
It is likely that the timer is stuck and will have to be replaced.
Posted on Sep 18, 2019
Is my asko d1776 repairable. It's currently not going into wash mode. The Blade are not turning and washing.
The motor is not getting switched on at the proper time. The timer / cycle selector is the problem and is easily repairable.
May 25, 2015 | Asko D1776 Stainless Steel Built-in...
My Asko W6022 quattro 1200 rpm is giving me trouble. The delicate cycle doesn't work and just soaks the clothes. Please help.
may have defective timer (burned points at the delicate cycle mode) can but may be difficult take timer apart and sand paper clean the point contacts on timer DONT IT BEFORE BUT NOT EASY
Dec 16, 2014 | Asko Washing Machines
Who do you set timer on asko 6461 washer?
the timer you are trying to set is for a delay start. so if you set the timer for 1 hr, the machine will start 1 hr later.
Feb 05, 2011 | Asko W6461 Front Load Washer
Asko 10505 will not spin the belt is not broken, tub fills and drains
Your washer unit is needing a new timer and replacement is needed if the part is available.
This will require some electrical experience to replace the timer unit or go to your local Sears repair and they will come out and repair your unit for a fee.
Jan 29, 2010 | Asko Washing Machines
Our office has a new Asko d3112 dishwasher and maybe its just "user error" but we set it to wash and it stayed on for 3hrs? How do we set it to a normal wash? Simple question but for busy accountants we...
This is probably not 'user error'. No machine has a 3 hour wash cycle. The timer will not advance if the water is not up to the proper temp. A severely extended wash cycle is usually caused by a faulty heating element.
I assume the water supply line was hooked up to the HOT water and not the cold. And you run the sink until hot water is present in the line.
The next time you run this machine, allow it to operate for a few minutes, then open it up and see if a ball of steam escapes. No steam = no heat = no timer movement.
If this is the case, the resistance of the element will need to be checked with a multitester set to ohms. A faulty reading will be zero or overlimit or infinity and the element will have to be replaced.
It may also be as simple as a broken or disconnected heating element wire. Good luck
Dec 04, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Washing Machines Logo
Top Asko Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
ThaMp3Doctor
ThaMp3Doctor
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
