Question about Samsung Refrigerators
Why is my samsung refrigerator flashing 34 on temp display and not cooling properly
Posted by Arthur Burbank on
Jorgie Navito
    Master:
  • Samsung Master
  • 357 Answers
SEE ATTACHMENT LINK
Posted on Mar 29, 2020
5 Related Answers
Anonymous
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
Anonymous
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
Anonymous
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
Anonymous
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
Anonymous
  • 5 Answers
SOURCE: Fridge not keeping cool RS267LASH
Hi Adshegern,
I think you have a fan problem. Your refrigerator mus have a bad fan or not working fan. I suggest you full out the refrigerator and open back lower cover. Two months ago, I have a problem like your. I fixed by replace a fan. You have to options to fix it.
Option 1. Check your refrigerator's fan with voltage. It think it should be 120VAC. If yes, you can buy a fan from electronics store (it cost about $12.00 to $17.00). they you remove the old fan and its motor out. Install the new fan in. Then you need to drill 4 holes to tie the fan. By doing this, you keep the fan running stable. The fan won't vibrate.
Option 2. You can go online to this website partstore.com and buy an exactly the one you need and replace the old one. It cost about $40.00.
Good luck
Posted on May 22, 2009
Samsung RS2556BB display is flashing on 34 degrees for refrigerator side; does not seem cool-- what could be problem
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 13, 2011 | Samsung RS2556 Side by Side Refrigerator
How can we install a electronic control panel on
very unlikeley to be the user control panel probably the freezer sensor or freezer fan not operating so no cold air circulating giving a false reading? is it colder at the bottom of the freezer than the top ? that is a dead give away for the fan
Jul 25, 2009 | Samsung RS2630SH Side by Side Refrigerator
The refrigerator temp keeps returning to 65 after I set it at 34.
After you set the temp (at 34) the refrigerator display changes to show the current temp inside your refrig. (apparently it was 65) As the unit runs, this display will lower until arriving at the set temp.
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
Samsung rs2533sw fridge not cooling
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Dec 01, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Nov 20, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
288 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
