Question about Teac Audio Players & Recorders
Where can I purchase Solenoid for Teac Model A-4010 S Reel to Reel Tape deck
5 Suggested Answers
Anonymous
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
Anonymous
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it [email protected]
Posted on Jun 20, 2008
robotek
Graeme Ross
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
Warren Albee
  • 4 Answers
SOURCE: Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Posted on Aug 31, 2009
Grubhead
Grubhead
  • 5699 Answers
SOURCE: akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Posted on Sep 11, 2009
Why does tape go slow, then stops?
Gary hi! I am not sure whether your machine is solenoid controlled but if it is then I would suspect the solenoid that operate the capstan roller to be overheating, I had the very same problem with my Studer and Revoxes and when I smeared some heat sink compound (Available from electronic stores selling components like Radio Shack etc.) and fit if the chassis is cast aluminium like the better manufacturers use,as a heat sink. You can chech the belts and the lubrication of the drive system but I doubt that. Clean the capstan roller with denatured alcohol or cleaning alcohol.
Nov 11, 2014 | Audio Players & Recorders
Will teac rc-120 remote work with teac a-3440
No. It requires a newer type of the RC90 or RC70 models with 12 pin rectangular plug
May 03, 2014 | Audio Players & Recorders
FF problem on Teac Reel to Reel
You need new brake pads installed as the ones in there now are dried up and may have fallen off. This is very common with older decks or 30-40 years old.
I am still working on these decks at Skywave Tape Deck Repair in the Chicago area.
Jul 15, 2013 | Teac Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
How do you thread a teac model 40-s tape player
There is no such model.
If you have a A4010S. The tape comes off the reel under the tension arm, over the reverse sensing post, under the heads and lifters, over the
capstan shaft (in between the capstan and Pinch Roller) then under the right tension arm and on to the take-up reel.
Dec 15, 2011 | Teac Audio Players & Recorders
How do I connect a teac ax-20 mixdown panel to a teac a-3340s reel to reel?
It's a 4-in, 2-out panel. Well, you attach up to 4 INPUT channels (labeled plainly on it) and run the two output channels to any two of the the Record In connectors on the Tape Deck.
Sep 11, 2011 | Teac Audio Players & Recorders
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
Would the owners/service manual for the Teac X-1000R reel to reel tape deck be available for download??
You can download the user manual from:
http://safemanuals.com/user-guide-instructions-owner-manual/TEAC/X-1000R-_E
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa
Jan 08, 2010 | Teac Audio Players & Recorders
Hi jvanheul
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
