Question about Waring Kitchen Appliances - Others
Where can i find replacement screw ring waring pro cm100
Posted by SAMUEL CRAIG on
Tom Chichester
    Top Expert:
  • Waring Master
  • 57,296 Answers
Waring would be a possible source.
Posted on Dec 24, 2019
How to remove cover from waring pro wo50
A broken cork was stuck up inside my Waring Pro Wine Opener. Model WO50B. No amount of maneuvering could get it out. I removed the two small screws holding the silver part of the opener on. After that was off I could see two more screws and I removed those. The unit still would not come apart. I noticed that there were four oval shaped rubber plugs up on the black part of the unit. I pried the ovals out with a wooden skewer. That exposed the other four screws holding the long part of the unit together. Once I got those out, I gently pulled the two sides apart about an inch. I could have pulled it completely apart at that point (I think) but from there I was able to free the broken cork from the big internal cork screw. Everything screwed back together fine and the unit works again.
Nov 20, 2013 | Waring Pro WO50 Cordless Wine Opener
CM100 Cabel Modem refuses to turn on?
You may can try by resetting and re configuring your router but make sure to backup your settings first.
Jan 15, 2013 | Linksys CM100 Cable Modem
Where can I purchase a replacement bread pan for my Regal Kitchen Pro K6725 breadmaker?
web search- regal ware k6725 pro bread maker parts- click on 3rd site for parts
Oct 08, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
Screws that hold bottom and top together have come out - appears that plastic that they screw into has melted
I repaired the broken "clamshell" of my Waring Pro WMK300 Professional Belgium Waffle Maker by replacing the original screws with a pair of (black metal) #8 x 1.125 inch flat-head machine screws and anti-vibration lock-nuts. These nuts have a nylon insert to prevent loosening. The assembly is now strong enough to pick up by the handle.
I drilled into the original plastic pits to create through-holes. I chose screws just long enough to fill the anti-vibration lock-nuts without protruding. You will need to hold each nut with a wrench or pliers while turning the screw into the nylon of the nut. Tighten just until the waffle iron assembly is snug, then another 1/8 turn. The torque should increase only during this last step.
The nuts are visible when I flip the iron, but I don't mind - they just remind me that the iron is now stronger than factory design.
Feb 23, 2010 | Waring WMK300 Professional Belgian Waffle...
Stripped gear on our Waring Pro FS150 Food Slicer
SmallAppliance.com has the part you need. Waring is no help at all. They only sell the replacement blade! Go to this web site: http://www.smallappliance.com/product.asp?pid=5147&cur=USD&cam=waring_parts&sid=18956&mid=34&gid=18971&prdCls=P&PartsPaNu=1&shopBy=Brand
and get the part. Thankfully they carry the motor gear you need. I had nothing but frustration dealing with Waring trying to get this part. Finally a nice Waring tech told me about smallappliance.com. Good Luck!
Apr 23, 2009 | Waring Food Processors
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
Kitchen Appliances - Others Logo
132 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Jim
Ps Daengr
Ps Daengr
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
