Reviewing pictures on computer, day pictures look great, night pictures are black. Sensors must be working pictures are random times at night but pictures are just black
SOURCE: Random Pictures?!??!
look for a small opening to insert a pin. many companies offer this hole as a way to reset the micro-controller. insert the pin during power up
SOURCE: Kodak C643 Screen black
One way out of the glare is to use the optical viewfinder (if your camera has one) to preview your image instead of the LCD. Another possibility is to buy a camera that has a backlit LCD.
SOURCE: 1998 Ford Explorer v- 6 OHV Check engine light
OK. Since you have had so much trouble lets check the dealer for an updated software calibration for the PCM (power train control module). Once we're sure there is no "fix" here lets talk about "lean" engine conditions. Lean means one of two things are wrong with the air fuel mixture (ideally 14.7 parts air to 1 part fuel). 1. Too much air -or- 2. Not enough fuel. If you access to a scan tool we need to look at fuel trims. With the engine warm look at this data on the scan tool. You have a "bank 1" and "bank 2" fuel trim data. Additionally, each bank has a long term and a short term value. With the Engine hot and at idle add the LT and ST trim value for bank1 and write it down...do the same for bank2. Repeat this step, for EACH bank with engine at 2500 RPM in park (hold at 2500 for at least 30 seconds so trims update). Now, you have the total trim values for each bank at idle and at 2500 RPM. What should the values be? Total trim +/- 5 is good, +/- 10 borderline any thing greater is code setting territory. If trim numbers are high at idle and in range at 2500 rpm you have a vacum leak behind the mass air flow sensor. Or a faulty MAF. Pay particular attention to the air inlet hose clamps behind (between MAF and engine) the MAF. Also use ford parts only.
SOURCE: Picture goes black
I had the same problem. Could you let me know how to replace the power supply? Thank you in advance.
SOURCE: Moutlrie I-40 IR flash doesn't seem to work
error 020000 relates to flash/flash charging...if new, take it back.I have repaired several by replacing the IR LED flash...easier fix than the incandescent units.
