Question about Lands Phones
SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Posted on Feb 12, 2008
SOURCE: Calls go straight to voicemail
Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
Posted on Dec 28, 2008
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Posted on Jan 16, 2009
SOURCE: iphone problem making and receiving calls
hi, we offer iPhone repair parts. www.lunacommerce. welcome to mail me [email protected] for more information. we accept paypal.
Posted on May 08, 2009
SOURCE: Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
Hope this helps someone?
vandata1
Posted on Mar 11, 2010
Feb 14, 2016 | Samsung Galaxy S6 Edge
Nov 27, 2015 | Samsung Tracfone Sgh T105g Cell Phone...
Jul 11, 2015 | Cell Phones
Jan 20, 2011 | Cell Phones
May 30, 2010 | Motorola Mobility RAZR V3
Apr 06, 2009 | AT&T Nokia 6555 Cell Phone - Black
Dec 11, 2008 | Toshiba DKT-2020 Corded Phone
Dec 08, 2008 | NorStar M7310 Corded Phone
Dec 02, 2008 | NorStar M7310 Corded Phone
Mar 20, 2007 | Nokia 6255i
122 people viewed this question
