Hi Ray Lynam, for what you say, you could have a problem with the speaker output
I suggest you remove the cover and look for two F2 and F3 fuses of 4Amp each that correspond to the output of the speakers, check if they are burned, if so replace them, ONLY FOR FUSES OF EQUAL VALUE 4AMP, do not put more value because you could produce major damage, test the equipment and if they burn again, then if you have problems at the exit stage
In this case, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Ray Lynam, por lo que comentas, podr?as tener problema en la salida de parlantes
Te sugiero retirar la tapa y buscar dos fusibles F2 y F3 de 4 Amp cada uno que corresponden a la salida de parlantes, controla si est?n quemados, si es asi reemplazalos, SOLO POR FUSIBLES DE IGUAL VALOR 4 AMP, no pongas de mayor valor porque podr?as producir un da?o mayor, prueba el equipo y si se vuelven a quemar, entonces si tiene problemas en la etapa de salida
En este caso busca un servicio t?cnico especializado
Espero que puedas resolver el problema
Saludos Franco Dosil
https://www.hifiengine.com/manual_library/denon/dra-350.shtml
SOURCE: MY DENON DRA-435 A RECEIVER
These recievers were infamous for the power transformers going bad(opening) if more than 2 speakers were hooked up and it was cranked up.Did it die while playing?Do you have 4 or more speakers hooked up?Was there a power surge?Let me know........
SOURCE: denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
SOURCE: No Power
There is a thermal fuse built into the main transformer. It is possible that the fuse is open.
Dan
SOURCE: My very old Denon AV Receiver (DRA-55V) works fine
check your speaker A - B channel push-button switchces. They tend to get worn and contacts internally corroded after all these years <!-- from fixya rte -->
