Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
Sony Grand Vega green light blinks on and then blinks red
On turn on it blinks green ~6 times, then switches to blinking red. Turning on again it will blink green and back to red. Eventually after a number of attempts it will stay on and picture comes on. But it is at point where it takes longer. When it does stay on, green light solid, a small fan becomes audible. A relay sound clicks off and the red blinking "LED" starts.
Anyone able to help. It will be much appreciated. Thank you
  • 1 more comment
  • Anonymous Sep 18, 2009
    welcomejee,
    Sorry, I think you didn't get an answer to the questions you had requested.
    The model # of my Sony Grand Vega: KF50WE610.
    The red lamp blinks 6 times in rapidly(~3sec), then there is a 3 sec pause, then rapid 6 blinks, followed by 3sec pause. This repeats till power is disconnected.
    The TV is about 5 years old and the lamp has been replaced twice since new.
    Thank you for your interest.
    caport99
  • JULIAN STOYANOV
    JULIAN STOYANOV Jan 07, 2014
  • Anonymous Mar 27, 2014
    I have an old ibm desktop and when I turn it on the green led for hard drive keeps on blinking and it blinks 6 times and stops and it repeats tue same thing again and again and the computer wont start please help
Shahid Electronics
  • 10,594 Answers
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Posted on Sep 14, 2009
Testimonial: "You are on the right track even with my poor explanation. Thank you"
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Sep 22, 2009
    Sorry for delayed reply due to website system that does not show your comments for some reason.
    6 times led blink shows problem in power supply board (G1) and need to test +/- 17 volt supply specially.
  • lchavez735 Oct 25, 2010
    i have the same problem with KF-60WE610 it takes about 6-7 times turning on the power button, can i do the test my self ? or should i call a cert. repair Tech. and if the /- 17 volt is bad can i replace the board or use a Tech.
    help!!
  • JULIAN STOYANOV
    what is G1?is this a serious problem?
  • JULIAN STOYANOV
    when i try to start TV green led blink 10 times then just flashes red
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
MY SONY TV MODEL # KF42-WE610 IS SOUND IS COMING ON BUT NO PICTURE
If you turn it on and the, Power/Standby green light blinks slow 6 times; then it becomes a red fast blink 6 times, pause, then continues to blink red fast 6 times, again and again. this means when it's blinking 6 times is indication of electrical circuitry malfunction. The Television will need service.
Sep 30, 2014 | Sony Televison & Video
Sony KDF-60XS955 LCD Projection HD Grand Vega. Turns itself off every 30 secs or so. Flashes green light 32/33 times. Comes back on with picture but no sound. Then sound comes on at green flash 37 and...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Feb 20, 2018 | Sony Grand WEGA KDF-60XS955 60" Rear...
55' sony grand wega will not turn on. The green light blinks 5 times and then red light blinks 6 times. red light cycles 6 times again. What is the problem? Can I fix it myself?
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care.....
Dec 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony grand vega 55" will blink green for three times than red blinking under the power light. nothing comes on no sound, no picture and no fan's are running. Tried to change the bulb, power board...
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
May 15, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv blinks and turns off
You likely have an open thermal fuse. There is a whole procedure for replacing the thermal fuse and some adjustments that should be done when you replace it. If you feel like you are reasoonably technical and can handle the job, I'll try and walk you through it. If not, your best bet is to find a qualified Sony tech in your area. If you contact Sony at 800-222-SONY and they can recommend one in your area
Nov 14, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
2,390 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
