Question about Bernina Sewing Machines
My bernina 770B won’t respond to touch on touch screen. Could i have overloaded it by looking for something on it and now it’s mad? Lol. Should i just shut it down for a while then it will work?
Posted by Margaret Rau on
3 Related Answers
SOURCE: touch screen on bernina artista 180 is slow to respond, is it expensive to repair
contact a sewing machine shop & ask them repair technican
Posted on Aug 07, 2012
Heather
SOURCE: bernina artista 180 touch screen slow to respond
A slow screen response time could indicate the touch screen or logic board is failing -- both are very expensive to replace (more than what you're paying for the machine.) Ask the seller to get a repair estimate from an authorized dealer, and talk to that dealer to be sure you're getting the full picture.
Posted on Aug 08, 2012
bargainbox
Hassy
  • 1388 Answers
SOURCE: My Bernina Artista 180 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
This Replacement LCD Touchscreen is suitable for your Bernina Artista 180
Bernina Artista 180 Replacement LCD Touchscreen
Posted on Apr 20, 2014
Bernina 880 will not respond to touch screen
Recalibrate touch screeen:
Access is achieved by simultaneously pressing the needle position buttons < > and at the same time switching the machine on.
• Brightness is adjusted by turning the stitch length knob.
• Touch the cross symbols on the touch-screen for calibration.
Jan 01, 2017 | Bernina Sewing Machines
How to calibrate the gel on the touch screen of the bernina artista 180
Sounds like something you should ask your Bernina repair service.
Nov 17, 2015 | Bernina Artista 180
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
Pfaff creative 7570 touch screen doesnt work
it's possible that the computer has gone out, since it's used it would be a good idea to have it checked.
Mar 08, 2014 | Sewing Machines
Bernina 780's LCD doesn't respond to touch
Sorry you are having problems. This is either a bad screen, loose cable or bad CPU. all of these need an authorized dealer to repair. In the future it is best to keep these on an uninteruped power supply and only use a stylus on the touch screen.
Nov 17, 2013 | Bernina Sewing Machines
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
Bernina artista 180 touch screen slow to respond
I would suggest contacting a sewing machine repair shop
& ask them about the slow response of the screen, & see what they
say & base your decision on that
Aug 07, 2012 | Bernina Artista 180
Sewing Machines Logo
112 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
