Question about JVC Televison & Video
On my jvc tv ipad connected with hdmi cable does not work
On my JVC tv when i connect ipad air with hdmi cable it use to work well but now it has stopped working no pic no sound and no charging. The cable is ok as tried on another setup. Please help. Thanks
5 Related Answers
Anonymous
  • 298 Answers
SOURCE: JVC THD-50 system
Yes, that is correct. You can either use optical or digital for the audio to the jvc system. They give you 2 options but you can use either, they both work just as well.
Posted on Apr 05, 2008
Anonymous
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
OT Bobby
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
joshter32
Josh Hubbard
  • 82 Answers
SOURCE: no sound from JVC do have sound from TV connected
hey man my names josh i used to work in home theatre if you can clarify what your problem is i can walk you through it my cell is 832 248 4144 on thing thing yo want to check with that no sound being produced out of of hdmi is to make sure that the port that you have it running to on your tv does not have a set of analog jacks next to it. if thats the case you want get your sound cause you will have to run sound with your hdmi next to that port on the tv that is if your tv has that function and providing you have more than one hdmi port on your tv it will most be the first port you have it pluged into if not you may need to check your wiring and your pre sets on the tv as well as your wiring that your have going to every thing cause i cant promise you that everyting may be hook up like it should but i can straiten that up for ya like i said my name is josh and my cell is 832 248 4144
Posted on Nov 02, 2009
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: I have a JVC HD-FH96
It sounds like it may be either the HDMI port on the TV that has an issue, or the HDMI output port on the Dish Network box. Do you have another HDMI device that you can try in that HDMI 1 port on your TV? HDMI should be very easy to use, you should be able to plug it in, switch to the HDMI input on the tv and it will pick up and adjust to the signal. Even if it was at an unsupported resolution / screen size it would at least have sound. There is definitely something going on with one of the ports... you need to determine which. Hopefully it is the dish network box as they should replace that for free.
It could also be the HDMI cable now that I think of it, do you have another HDMI cable you could test with?
Thanks, let me know!
Tim
Posted on Sep 18, 2010
I have a JVC HD-70FH97 hooked to my digital box, via HDMI cable, and connected to the TV HDMI input 1. I cant get my surround system to work - any ideas what im doing wrong?
Check your HDMI audio settings. It may be trying to send a signal that is incorrect. How is the wiring setup? cable box to stereo, then to Tv?
Sep 21, 2016 | JVC HD-70FH97 70 in. HDTV Television
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
How can I connect my JVC Everio GZ-MG155 camcorder (with a dock) to the HDMI tv input? What kind of adaptor(s) would I need?
The Everio GZ-MG155 and the dock supports an special A/V cable with composite ( http://store.jvc.com/product.asp?Model=QAM0120-001 ) or S-video ( http://store.jvc.com/product.asp?Model=YTU94146A ) cables for a TV with an analog tuner (NTSC). These signals are 480i. If you want to connect this analog signal to the HDMI port, you need an analog to digital video converter (and the appropriate cables). Something like this would work: http://www.monoprice.com/Product?c_id=101&cp_id=10114&cs_id=1011406&p_id=9994&seq=1&format=2 . This model will attempt to upconvert the signal to an HD format (720p minimum). Additional converters are here: http://www.hdtvsupply.com/cotohdco1.html . The A/V to HDMI cables will not work so check out these products carefully.
The manual for the JVC Everio GZ-MG155 is available on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL027855 . The direct link to the Instruction manual is http://resources.jvc.com/Resources/00/00/91/LYT1668-001C.pdf .
I hope this helps. If your TV has the legacy analog ports, you just need the original A/V cable.
Jun 03, 2015 | JVC Video Cameras
Laptop will not connect to tv
the tv might not be able or new enough to handle the picture of a laptop or computer check to see if it is able to
Apr 23, 2013 | JVC Televison & Video
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: http://resources.jvc.com/Resources/00/01/14/YA653ien.pdf . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
My HDMI connections aren't working. How do I
Tries unplug and replug the tv back about an hour.Let the tv reset itself back to factory setting.Now go in ur menu go to PICTURE.Go down the menu pick reset,that to reset all the funsctions in the Tuner board.This process should get all the HDMI Hub. working again,not than ur Tuner board have all the HDMI Hub. are shorted and dead.
Apr 27, 2010 | JVC LT46FN97 46 in TV
Cant get our HDMI to work on our JVC HD 58S998.
First, contrary to popular opinion, HDMI cables connect to a tv are not the best way to connect the two. The HDMI technology has flaws that often shows up as sound problems.
If your TV has the capability for component connections, use them. It will take 5 cables, 3 for video and 2 for audio. You will get superior sound and video. The 5 cables terminate in RCA type connectors and are much cheaper than an HDMI cable.
I hope this helps and solves your problem. :-)
Jan 03, 2010 | JVC Televison & Video
Jan 12, 2009 | JVC AV-36D303 36" TV
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Apr 03, 2008 | JVC THD-50 System
Televison & Video Logo
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
