Question about Cycling
Schwinn Quick Wrap 400 Lumens LED Light Set: Do you know where the access point to the USB port is on the rear light for this model? Cannot find anything on internet or Schwinn websites. Thanks!
Posted by Chris Wayton on
5 Related Answers
Anonymous
  • 790 Answers
SOURCE: jvc hd61z575 61in. rear projection tv won't come on
ok you have defective power supply in hotside section! maybe they have abnormal oscillation!
Posted on Oct 11, 2007
Anonymous
  • 611 Answers
SOURCE: SMC EZ Connect Access Point apparently not connecting to wired router
you doing something wrong there.
give the mac address of smc to the access point that's all you get it
Posted on Jun 20, 2008
Anonymous
SOURCE: thinkpad T20 won't recognize usb port
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Posted on Jan 27, 2009
Anonymous
SOURCE: USB light doesn't lit when i plug in my Tascam US-122
i need sound drivers
Posted on Mar 28, 2009
There are some white dots on the projection
The DLP chip of the projector has gone bad, which require to be replaced.
Aug 17, 2015 | LG HS200 SVGA 200 lumens LED Projector;...
I want to know how I can re-set my 3Com 3crwe955275 wireless access point to its default factory settings. Can anyone help?
1 Remove power from the Gateway. 2 Disconnect all your computers and the cable/DSL modem from the Gateway router. 3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports. 4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway. 5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports. 6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to: http://192.168.1.1 and run the configuration wizard. You may need to restart your computer before you attempt this. 7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
Feb 18, 2015 | 3Com Computers & Internet
Linksys wireless g 2.4 ghz usb link light off
Kari,
If you do not have anything connected to the USB port, the associated LED should be off. If there is something connected & powered up, then it probably should be lit. Try a different cable or connect a different device (hard drive, printer, etc.). Which router model number do you have & what device are you trying to connect to it?
Oct 31, 2013 | Linksys Computers & Internet
How to change the batteries in Schwinn Tool Free LED light Set
You have to keep the black rubber, triangular button depressed while you slide it opposite way of the LED lights.
(Just face the LED lights side to your body,depress black rubber button and slide down)
Hope this helps!.
Feb 03, 2013 | Schwinn Tool Free LED light Set
Hid light output?
MH lamps are available in 175,200, 400 and 1000 watt sizes. HPS lamps come in 50, 75, 150, 400 and 1000 watt sizes. San Agro comes in 430w only, but it works with a 400w HPS ballast. Each lamp requires its own ballast, which comes with the fixtures that are designed to use these lamps, and are also available separately.
Aug 27, 2008 | Hydrofarm Agrosun Dayspot 60w Grow Light...
Cycling Logo
197 people viewed this question
Top Cycling Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Cycling Expert? Answer questions, earn points and help others
