Question about Hisense Televison & Video
HISENSE 49N2170PW -DISTORTED PICTURE - WE REPLACED THE MAINBOARD AND THE T-CON BOARD
Posted by Dirk van Vuuren on
David Spradling
    Top Expert:
  • Hisense Master
  • 11,320 Answers
Go into set up and change picture size
Posted on Jun 03, 2020
5 Related Answers
scorpi092
alexander hernandez
  • 53 Answers
SOURCE: picture look like a negative film. color not normal. no green color
you might want to start with the t-con board. it can cause green colors missing
Posted on Nov 11, 2013
Michael Carroll
  • 742 Answers
SOURCE: I have a samsung lnt4066 led TV with a distorted picture. I have replaced the main board, power supply and the t con board with no success. I have pictures of what the TV is doing and would like to sh
You either have a bad t-con board or the screen is bad. Check to make sure all the ribbon cables are seated fully and connected. Even replacement parts can be bad sometimes, new and used both.
Posted on Jan 09, 2015
richie46
  • 12962 Answers
SOURCE: My Phillips 47 LCD TV is loosing picture but is keeping sound.
Main board feeds the t con board. However try the flash light test on set because it might just be the inverter board that powers the backlighting.
Posted on Mar 17, 2016
richie46
  • 12962 Answers
SOURCE: If I have replaced the T-con board, the mainboard, and the board with the inputs, and my TV image is still not showing up, what should I do to fix the problem? Is it the LED driver?
Other than the PS you have replaced all save for the inverter board or as you call it led driver.
Posted on Aug 11, 2016
Larry
  • 2800 Answers
SOURCE: I can’t find the T con board on my Coby TFTV 4025 LCD tv. From what I can tell there is only the Mainboard, Powerboard and Inveterboard. Does anyone have any pictures of where this board is located?
Reason you can't find it is there isn't one, on some low end TV's like this one they build it into the panel board to save a buck or 2 so if the tcon has issues the set will need to be recycled
Posted on Mar 22, 2018
Hisense t-con board
The T con board digitizes the data that finally appears on your screen. If a picture has distortion and other anomalies, this board is responsible.
Sep 17, 2016 | Hisense Televison & Video
I have a 50 hisense an the screen is has a flickering picture.What needs to be done??
Check the T-Con board and the back light driver board for loose connections
Aug 07, 2016 | Hisense Televison & Video
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
Jan 13, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
Why is my TV burning through T-Con boards? Ever time I replace one, it works for 2 hours and then I lose picture again. I've replaced 2 so far.
Hope the TV have problem with the either power board or the lcd panel. Try to check the power supply is its produce correct voltages mentioned on its connectors if you need help then check the video for that. if the power supply finds ok then you have problem with the lcd panel. In lcd panel there is a some ics which used as the driver of the pixels. the tcon sends data to these ics. and if any onf the ics draws more current from t con board then it can dame the t con. They are not replaceable one ,its integrated to the panel. if its faulty then you have to go for a new panel for that tv. And it would be a expensive repair.
Testing LCD TV Power Supply BoardsSTEP BY STEP
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
http://electro-medical.blogspot.com/
Nov 11, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
Picture is sepia like(just terrible)
This can be caused by two things, the first thing to do is disconnect the LVDS cable from going from mainboard to T-Con board the small board in the top middle of tv with a metal plate over it.
Clean the contacts of the cable and reattached the cable.
If picture still the same the T-Con board needs to be replaced.
In case of T-con Board replacement also check the power supply for bulging capacators because they can be the cause that the T-con board died.
Jul 09, 2013 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
Very blotchy picture color distorted get pink green blue splotches
This problems,I've fixed it before.The board called the T-CON board it have some kind of a shorts in it circuitries parts to project this kind of a picture to the LCD screen panel to have this problems.The T-Con board sit in the middle of the bottom of the tv LCD screen panel,90% of the LCD tvs out there that where the T-CON board sit.If u have some basic mechanic skills like take things a parts and putting things back together again.U should have no problems at all by replacing this T-Con board.Tries websites like Shopjimmy.com,EBay.com to buy a refurbish T-CON board for the replacement.
Feb 06, 2013 | Televison & Video
About 3 yrs old. Picture is distorted for about 1/2 hour until tv warms up. Now has horizontal lines going through the picture and stays distorted on the right side of the screen.
This tv problems it is alway the board that call the T-CON decodering board it is dying.This T-CON decodering board sit in the middle at the bottom of the tv LCD screen panel.This T-CON decodering board decodes all the tv picture dots pixels before it go into the tv LCD screen panel itself.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish T-CON decodering board for the replacement.
May 09, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
64 people viewed this question
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
