Question about Cameras
My a200 won't work after formatting a I b m flash card
Hi can anyone help me or is my camera Useless .I formatted an I.B.M flash card as for some reason it would not recognise it been all right for years but stopped working stayed can't recognise card went into settings found format it asked me if I wanted to clean pressed yes the bar filled and stayed complete went to switch over to camera and camera was dead I know that it must be the card as it would not work in my a2 and luckily enough it would not format it is it a firmware problem and can it be rebooted and how do I do it many thanks steve
Posted by Steve townsend on
Kristyanna Virgona
    New Friend:
  • 28 Answers
Sometimes a flashcard stop working. depending on the Age of the card. they do have a finite amount of reads and writes. its like and SSD if there are too many bad memory cells on the chip and it can get enough errors or bad cells to the point you cannot format it. if you have a PC and have a reader for the card you can try to format it as Fat32, if that fails get a new flash card. if you are using a CF card or the Sony Memory Pro card
Posted on Oct 03, 2019
5 Related Answers
Anonymous
SOURCE: compact flash cards
what is the solution for this problem posted by tiller on Sep 26 2006
Posted on Apr 15, 2007
Anonymous
  • 5 Answers
SOURCE: olympus C-750 Trouble formatting card
If the new card is bigger than 512 mb, it won't work in a C-750. The camera has a size limit of 512 mb. Anything bigger will give you a "Card error" error screen when trying to format it.
Posted on Nov 25, 2007
AMJAD HUSSAIN
  • 586 Answers
SOURCE: New PS1 memory card (OEM) won't work in slim PS2
PS1 memory card do not work with the PS2.You have to buy PS2 memory card to save for PS1/PS2 games using PS2 game consloe.
Posted on Oct 09, 2008
Anonymous
  • 161 Answers
SOURCE: hi,just bought a 4gb sd card for my digimax s600
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Posted on Sep 09, 2009
Testimonial: "hi,thanks for the quick response,i don,t know if it has what you said.it just says on the bottom of the camera..digimax s600 cyber/630."
Ty Price
  • 11967 Answers
SOURCE: Kodak Z740 camera sd card formatting problem
Remove the card...turn on the camera and go into the menu...find "reset"...follow the on-screen instructions. Then try to format the card again.
Posted on Dec 18, 2009
My sony a200 wil not save my images to the memory card
Did you format the card before putting it in the camera
Jan 27, 2012 | Sony Alpha DSLR-A200K Digital Camera
Camera won't format media
Here is the link to the user manual if you need it; http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-a/dimage_a200/A200_Eb.pdf First thing to try is cleaning the electrical contacts on the card, gently with a soft dry cotton cloth. Check page 138 of the manual for instructions to reset to factory default settings - also worth trying. Have you tried formatting the card on a PC instead of the camera? What type of card are you using? The camera is compatible directly with CF cards and Microdrives, and with an adaptor can use SD and MMC cards. Possible problems are generally different for each type of card. That said, if the card will not format on a pc, then unless it is somehow password protected or write protected (depends on card type), the fault must lie with the card. Only way to be absolutely sure is to try a new card in the camera, if that also doesn't format then there is a more serious problem. From what you have described so far, it sounds as if you have a CF card, and it is faulty - these cards do have a tendency to do this. Please post back with some more details so I can be more certain. Hope this helps :)
Jul 08, 2007 | Konica Minolta DiMAGE A200 Digital Camera
My fuji finepix a200 camera is showing protected card. i cant get it to go off. How do I fix this
I'm going to show you a diagram that has to do with the card lock on the side of your memory card this slide is there to protect a card with images on it so it's not put back in the camera and formatted
Once you have unlocked the memory card you need to format the card to make it ready to accept new pictures from your camera. I hope you download your images first before formatting.
Dec 25, 2010 | FUJIFILM Finepix A200 Digital Camera
My Konica Minolta Dimage A200 do no recognize the memory cards. Can anybody help e to solve this problem?
Format the cards in the camera. Make sure you download any pictures that might be on the cards first. Use a card reader if necessary.
Oct 12, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Can't format a memory card for my minolta damage
Some brands cannot be used by some cameras. You should stick with the big brand names like Sandisk.
Sep 28, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Memory card not working
If it,s an SD Type memory card. Try formatting it in a Card-reader Connected to a PC. Format it In FAT Or In FAT32. If the card is not formatted. The camera won,t understand what it is.
Thankyou for using Fixya.
Mike @ Compurepair.
Mar 26, 2009 | Kodak EasyShare M1033 Digital Camera
Camera says this card cannot be used on power up.
either the card is not supported or it needs formatting
Nov 25, 2008 | Nikon COOLPIX L5 Digital Camera
Formatting flash card
perhaps you have a faulty card. Try another card and see what happens. If not then it may be the operating system which is at fault.
The following alert appears, "Unable to use card. Format?".
The following conditions are presumed: - File system of the card was changed by formatting with PC. - The card was formatted with other memory card device. Basically we recommend the users to format by using the camera. (All the data in the memory card will be erased.) As the memory card may have defects in itself, please try other memory card, if you have other memory cards.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
Cameras Logo
125 people viewed this question
Top Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
