Question about Tools & Hardware - Others
How to open the gun to load it. - Tools & Hardware - Others
Posted by Merle Selley on
How do I load nails into the 5700
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
May 20, 2011 | Garden
How do i open the stanley tr110 staple gun to load the staples
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
Mar 01, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
How to load brad nails
UNPLUG
look for image of brad nails on tool, load this side only.
Hold upside down.
Pull base back, and swing open......
Be sure they dont fall out, and make sure to use hi power ONLY.
Feb 14, 2011 | Electric Stanley Tre500 Staple Gun /...
I cannot get the staples in the staple gun. How do I load them properly? I have empty chamber and found the release. When I try to load them on the slide bar they don't want to advance to load.
Hi and welcome to FixYa. I am Kelly. This is a very crude users manual but see figure 5 on page one of the manual:
http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-5618325024065546262/view_document!PAGETYPE?sq=tre550&sc=2&sf=101113&sg=1&st=56327&documentid=172691&action=view
You must click on the Format PDF link to open the next page then choose save or open the document.
Everythng points to loading the staples via the slot vs on the slide bar.
Hopefully you using the correct staples. If your still having problems just respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Dec 17, 2010 | Stanley Tools TRE550 Electric Staple/Brad...
Can not reload lables in the gun
Depending on the type of gun that you have, loading will vary. Here is the most common style of label loading:
Loading
  • At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
    Insert a roll of labels into the gun opening so that the beginning of the roll is at the back and comes up over the top of the gun. Insert the beginning of the roll into the slot, squeezing the trigger halfway. Push the labels through the gun until they come out at the front. Thread the labels up and under the black plate on the front of the gun and then under the rubber roller. Squeeze the trigger again and pull six or seven labels out. Discard the labels, leaving the paper backing. Thread the paper backing into the underside of the gun, next to the handle, in the direction indicated by the arrow. Push the paper backing while squeezing the trigger until the gun begins dispensing labels.ixzz18ERFHy
  • Dec 16, 2010 | Office Equipment & Supplies
    How do i load the staple gun?
    1 Hold stapler upside down.
    2. Release black plastic catch at rear and pull out.
    3. Drop staples into bottom of gun, with open side up.
    4. Push black plastic catch closed and latched.
    wallyp
    Oct 30, 2010 | Stanley Bostitch Pc4000oc2 Outward Clinch...
    Need help loading staples in my Stanley electric staple/nail gun
    there should be a button / lever at the rear press it and it should open so as to insert the staples
    Apr 05, 2010 | Stanley Staple/Nail Gun Elec
    HOW DO I LOAD THE STAPLES IN MY STANLY TRE500
    Unplug. Pull out shaft. Flip over. Insert staples into open slot (not on top of shaft).Make sure points are up.
    Jul 15, 2009 | Electric Stanley Tre500 Staple Gun /...
    Staple gun
    Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
    Oct 26, 2008 | Stanley Bostitch Pc2000 Staple Gun Tacker...
    Powershot pro staple gun
    just purchased a Powershot model 5700m. how do you load the staples?
    Oct 13, 2008 | Powershot Tool Company Cobra 8000 Forward...
    Tools & Hardware - Others Logo
    134 people viewed this question
    Top Tools & Hardware - Others Experts
    Marvin
    Marvin
    john h
    Andrew Taylor
    Andrew Taylor
    Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
