Question about General Audio Players & Recorders
Operating manual for general electric clock radio model no. 7-4642A
Posted by Susan Palm on
5 Related Answers
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: clock radio
Unless thate is an internal fuse it that blew, most likely it will be more expensive to repair than replace. The transformer primary winding is probably burned out. You have nothing to lose, take it apart and see if there is a fuse. If so, replace it with the EXACT same value as the original. If not, its not worth fixing.
You didn't say what the symptoms were, other than it didn't work anymore. I am assuming it is completely dead.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 13, 2008
Ekse
  • 13434 Answers
SOURCE: A MANUAL FOR SONY CLOCK RADIO MODEL NO ICF-C253
Here you go
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/ICF-C253-_N
let me know if you need anything else. Thanks, Ekse
Posted on Mar 28, 2009
Anonymous
  • 3 Answers
SOURCE: i need to print a manual online for RCA clock radio model RC46
free manual
http://portablemedia.manualsonline.com/manuals/mfg/rca/rc46.html
Posted on Jan 15, 2010
Anonymous
SOURCE: a dead General Electric Model 7-4612B clock radio
The solution is to buy a new radio. Clock radios cost as little as $12 on Amazon.
Posted on Aug 21, 2010
Gyula Lacz
  • 486 Answers
SOURCE: I need an operations manual
I have found an operating info for you here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/12229/kw/cd%20clock%20radio%20rp5600A/session/L3RpbWUvMTMwODgzNzg2Ni9zaWQvQktCWDhleGs%3D
The owner's manual is available here also:
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RP5600_DOC_OM.pdf
Thanks.
gylacz
Posted on Jun 23, 2011
Need the Owners Manual on SmartSet Clock Radio
Jot down your model number.
Manuals for all Emerson products are available at http://www.emersonradio.com/owner_manuals.php Simply select your model in the drop-down menu and you're set.
Nov 29, 2015 | Emerson Smartset Clock Radio
Where can I get the instruction manual
If you are looking for the General Electric GE Spacemaker 75330 Stereo System Manual then let me know or look it up on audio.manualsonline.com.
Nov 08, 2010 | GE 75330 Clock Radio
I need to change the bulb in the analog clock in my 1999 Lincoln Towncar. How do I go about getting to it without tearing apart the dashboard?
you need a special tool to get the radio out. It has pins that spread out spring clips so the radio can pull out.
please rate as solved if this helps.
SECTION 413-00: Instrument Cluster and Panel Lighting — General Information 1999 Town Car Workshop Manual
REMOVAL AND INSTALLATION Bulb —Electric Clock
Special Tool(s) Radio Removing Tool
T87P-19061-A
Removal
  1. Disconnect the battery ground cable.
  1. Pull out the radio using Radio Removing Tool.
  1. Remove the radio.
    1. Disconnect the electrical connectors.
    1. Disconnect the antenna cable.
  1. Remove the instrument cluster finish panel bolts.
  1. Pull out and position aside the instrument cluster finish panel.
  1. Disconnect the electric clock electrical connector.
  1. Remove the instrument cluster finish panel.
    1. Disconnect the headlight switch electrical connector.
    1. Disconnect the dimmer switch electrical connector.
  1. Remove the electric clock illumination bulb.
Apr 23, 2009 | 1999 Lincoln Town Car
A dead General Electric Model 7-4612B clock radio
Jan 22, 2009 | Audio Players & Recorders
43 people viewed this question
Top General Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a General Audio Player and Recorder Expert? Answer questions, earn points and help others
