Question about Radio Communications
The usual cause is that the transmit button on the mike is broken or stuck in the "talk" position. If you disconnect the mike and the radio, then turn the radio on and it still is showing transmit, then the issue is inside the radio or the connector for the mike.
If the radio stays in receive mode with the mike disconnected, look at the mike connector for any bent pins or damage to the connector. If you don't see anything, try spraying electronic contact cleaner , the could be some corrosion that is causing a short here. Another thing, if you have it, is to use a different mike and see if that works properly.
Posted on Sep 24, 2019
Nov 02, 2015 | Uniden Lot Of 3 Gmrs 10-mile Range Uhf...
Sep 09, 2013 | Cobra 18 WX ST 40-Channels Base CB Radio
Mar 01, 2011 | Galaxy Radios Microsystems DX98VHP CB...
Feb 13, 2011 | Galaxy Radios Microsystems DX94HP CB Radio
Jan 07, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
May 07, 2010 | Cobra 29 LTD CB Radio
Oct 02, 2009 | Cobra 29 LTD CB Radio
Jun 04, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Feb 13, 2009 | Cobra 29 LTD CB Radio
Oct 29, 2008 | Radio Communications
133 people viewed this question
