Question about Kenmore Refrigerators
Where is the defrost time on my Kenmore coldspot side by 10650022210
Posted by Dottie Batiz on
Jon Bounds
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
This unit is too new to have a defrost timer. The defrost control is integraed into this board on this model.
WPW10366605
Posted on Sep 16, 2019
5 Related Answers
Anonymous
  • 195 Answers
SOURCE: Kenmore fridge Model# 106.56542400
Open the fridge side, look up.
Posted on Dec 07, 2008
Anonymous
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Posted on Feb 27, 2009
SolutionGuy
Tracy Farrell
  • 331 Answers
SOURCE: I have a Kenmore Coldspot Model 106.59502992 that
Hi Danda,
About 98% of the time on a Whirlpool built Kenmore such as yours the problem with automatic defrosting is the "defrost timer". It's super easy to repair. You can get one from Sears, a local appliance parts retailer or just about anywhere online (just plug this part number---> 482493 <--- into a search engine and price shop)
Here's a diagram I made. It details the repair. Number 4 says "ADC", don't worry. There are two types of defrost timers one is an ADC and another is yours. They both follow the same repair procedure, OK?
Here's a full size diagram of your machine. You'll see that there is no difference other than the type of defrost timer.
NOTE---> UNPLUG YOUR FRIDGE BEFORE DOING THIS REPAIR!!! Otherwise, you'll look like this permanently...
There ya go, Danda! Remember to rate this solution as "FixYa" WillYa?
SG
Posted on Apr 22, 2009
Anonymous
SOURCE: I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Posted on Jul 11, 2009
How to force defrost on a kenmore coldspot 10664253402
Your model has a board that controls defrost. I’m not aware of any way to put it in defrost. Some models after being unplugged for a certain time, will automatically go into defrost when plugged back in
Oct 26, 2018 | Kenmore Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Part number 6
Feb 27, 2009 | Kenmore Refrigerators
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
144 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
Dale Copeland
Dale Copeland
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
