My tv keeps shutting off all by itself. Do you now whats causing that?
Posted by Nancy Davis on
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 34,047 Answers
It can be caused by two things.
A faulty power supply board.
Overheating.
If it is concerning you, take it to a service engineer for your make of television.
Posted on Sep 15, 2019
3 Related Answers
Anonymous
SOURCE: My 42 inch samsung dlp tv keeps powering off on it's own. Why???
try tightening the screw on the lamp door. on mine the heat of the unit would loosen the contact which would shut the TV down.
Posted on Feb 05, 2010
Anonymous
  • 505 Answers
SOURCE: Our tv keeps shutting itself off.
this is a protective shutdown. it can be anything inside, but you can narrow it down. there are green LEDs inside, one for each voltage line. if one doesn't come up, that can be your shorted out voltage line. if you have a multimeter, you can ohm out all the fuses and see which one is blown to follow it to your failure. they are chemical fuses and you cant see if they're blown. either way, its going to be a somewhat tricky repair, and if you cannot solder or have a multimeter, best to leave to the pros. some of these just need 1 fuse and 1 cap, so it could be cheap, never know till you dive in. warning, this tv produces 30,000 volts so be careful.
Posted on Jun 01, 2010
SOURCE: PHILIPS 40PFL7705DV/F7 keeps shutting off
If it is a new TV and under warranty, return it. There is an internal fault and it needs to be serviced.
Posted on Oct 25, 2012
Oct 25, 2012 | Philips 40pfl7705dv/f7 40 Hz 120 Led Tv -...
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My dlp tv keeps switching itself off
take bulp vent cover off rear of tv. there is a little plastic switch that gets pressed in by this cover. i taped mine in because the cover wasnt pressing it in all the way and causing tv to shut off all the time. havent had a problem since.
Jan 11, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
My tv keeps shutting itself off automatically and the temp light keeps flashing.
this is a job for a service tech, because you are having problems with what it seems to be thermal shutdown. please refrain from turning it on you could cause further problems to set.
Nov 06, 2009 | Hitachi 42V710 42" Rear Projection HDTV
My TV shuts itself down by itself
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
TV keeps shutting down.
the power relay contacts are burned replace the relay
May 21, 2009 | Philips Televison & Video
Keeps turning off by itself after about 30 minutes
Is your air intake clean or clogged.. Maybe it's overheating causing it to shut off.. Had the same problem didn't replace the bulb but cleaned the intake and it works great again. Worth a try.. Intake is located on the left back pannel of the tv.. outside pannel pops off easly.
Apr 27, 2009 | Toshiba 42HM66 42" Projection HDTV
Your Lamp could be going out.they only play for 5,000 hr some 8,000 hours do the math.
Nov 30, 2008 | Samsung Televison & Video
My RCA TV 52inch HDTV makes a sizzlin sound and shuts off by itself
Your HV transformer (flyback) or HV block is cracked those are common problems with that model. If you want to do it your self heres a link that can help you. go to their site and leave an email about your symptoms.
http://servicemanuals.vstore.ca/
Apr 03, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
