Question about Samsung Audio Players & Recorders
I have Samsung SVR-S820 Voice Pen
How to transfer all recordings to a MacBook computer
Posted by Nourhan A. Marzouk on
  • Terry
    Terry Sep 15, 2019
    Apparently Voice Manager software included with the original unit on a CD-ROM, and possibly available as a download from the internet is needed to copy the recording to an IBM compatible computer, but apparently not a MacBook. So the steps would be to get the software, download the recordings to an IBM computer, and then use the internet or a removable device to copy it from the IBM compatible computer.
5 Related Answers
trexxtoo
  • 3 Answers
SOURCE: transfer recording from tape recorder to computer
Use a cable running from the headphone jack on the recorder into your PC microphone jack. Then you can capture the audio using Windows MovieMaker software that comes with Windows XP. I have done this and it worked perfectly.
Posted on Jun 10, 2008
Anonymous
SOURCE: Sims SVR-M935 driver
driver
Posted on Oct 14, 2008
Anonymous
SOURCE: cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Posted on Jan 29, 2009
Anonymous
  • 919 Answers
SOURCE: Digital voice recorder connection problem
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Posted on Jun 03, 2009
Anonymous
SOURCE: Samsung digital voice recorder SVR-S1330
http://downloadcenter.samsung.com/content/DR/200303/20030328170645359_VoiceManager.zip
Posted on Jan 04, 2010
Voice recorded is cracking sound
I guess there is wire inside your recorder that has been disconnected or the speaker has been damaged.. try to transfer the audio file into a computer test it to confirm.. Good luck..
I need software for this product, please deliver the software
1helpful
2answers
Samsung SVR-S1330 Voice Pen Recorder
do anyone have the samsung SVRS1330 driver for window xp for the port use
6helpful
3answers
Open Questions:
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
