Question about JVC KD-S580 CD Player
Missing a wire out of the back of my jvc kd-s580 radio need good picture to know were and witch one so i can put it back
Posted by Jesse Hurley on
5 Related Answers
Anonymous
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
Anonymous
  • 15 Answers
SOURCE: I need a user manual for this radio JVC-KD-S580
You can just type this into google or yahoo and you will find a manual, if you need anymore assistance, let me know JVC KD-S580 CD Player Manual
Posted on Nov 28, 2008
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
Anonymous
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Posted on Jun 10, 2009
taran_2005
taran_2005
  • 10515 Answers
SOURCE: I need to know how to set the clock on my JVC 180w KD S580 radio
Press and hold sel and press and hold disp. Use Vol+ and - to set the hour. Then press fast forward to get to minutes.
Thanks.
Posted on Jul 02, 2009
How do you hook up a jvc kd-s580 to a 91 ford explorer
Get a wiring plug kit. These are available at any Walmart. They are specific for your vehicle make and not the radio. Radio manufacturers typically use all of the same colors so this should be a matter of matching color to color straight forward. Double check this with yoru radio manufacturer schematic before applying power to the radio.
Here is the wiring diagram for your truck
Jan 20, 2010 | JVC KD-S580 CD Player
I cant get my raido to save my time or my radio
make sure that you have wired it to the manufacturers spesification, ie, that you have one wire, ususlly the yellow , going to a permanent, not switched power sourse
Oct 22, 2009 | JVC KD-S580 CD Player
Thanks.
Jul 02, 2009 | JVC KD-S580 CD Player
JVC KD-G245 - powers up, then turns itself off after 3 seconds
Try connecting battery and accessory wires as one instead of two seperate wires (yellow and red) had same problem and worked for me(it will not be neccesary to turn the key for the radio to work once this is done)
Mar 05, 2009 | JVC KD-S580 CD Player
Lost the connector on the back!
I would call kenwood and have them send me the connector, you can rig it with out one, but I gaurantee it will short from vibration over time
Feb 05, 2009 | JVC KD-S580 CD Player
Reset jvc radio KD-S580
push and hold power and eject together for 3 or more seconds
Nov 27, 2008 | JVC KD-S580 CD Player
CD loading.
je cherche la plate avant du radio model:kd-s580 marque jvc
merci de votre collaboration.thank you
Mar 25, 2008 | JVC KD-S580 CD Player
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
JVC KD-S580 CD Player Logo
122 people viewed this question
Top JVC Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Ekse
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
