Call Crutchfield 1 800 555 8303 they can and will help you because this is what they do they also have a website.
I turn the car off last night woke up to go to work an the car won't start lights all on red light of a car with a key in it is flashing fast try jump start charge battery still nothing just got this car too
YOU HAVE CONNECT A SEPERATE IGNITION WIRE YOU WILL NOT GET ACCESSORY BEHIND RADIO AT WIRE THIS IS DIGITAL SYSTEM CONTROL TRUE A FACTORY MODULE
SOURCE: 1999 Grand Cherokee Radio Wiring Harness Diagram/Color Codes
Go to www.installdr.com and search through the diagrams in there, the site is easy to use, all you need is acrobat reader installed on your computer to use the site, it has a full explanation on every wire color and what it is
SOURCE: color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
SOURCE: dimmer wire connection from aftermarket delco harness to alpine
One Of The Wires Should Be labeled Dash Lights That Comes Out Of Your Radio.
SOURCE: 2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not
provide a switched power source. Run a wire to the fusebox for switched
power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
