My mp3 is of drumstone company and is brand new
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Posted on Apr 15, 2009
SOURCE: Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Posted on Dec 26, 2009
SOURCE: Daytek DT4660 - at ac on , led grn for 2-3 secs,
Hi
I work on Daytek 4660 models. I have seen the problem you are having and have solved it a couple of times by replacing all the capacitors in the power supply. If you use an oscilloscope to measure the voltages they may appear fine, however I have solved this problem by replacing all the capacitors in the 2ndary circuit of the power supply. It doesn't always work, but has worked in about half of the TVs that have come in with this problem. Also, just to make sure, if you remove the shielding from the board that drives the LCD panel make sure the little smt fuse is good. It's right on the 5V power line close to the ribbon connector from the main board.
Posted on May 20, 2010
SOURCE: 10 red blinking lights on my Panasonic Plasma TV,
This is a power supply issue - found a company that has used power supplies, they sell them for $60.00. We recommend a professional install the board because the voltage needs to be adjusted after the install or you could damage something else. The high voltage in the set can KILL you soe be very careful. The web address for the PS board is plasmafix.com.
Posted on Jul 03, 2010
SOURCE: have second hand lexmark e260dn and status light
Blinking status light means the printer is busy. If it's not doing anything else, disconnect the printer from the computer. Restart the printer and then print a menu settings page. Clear the print queue on your computer before re-attaching the printer. Thanks.
Posted on Jul 30, 2010
Testimonial: "Thanks for your help. It looks like this can't be repaired though so I'm getting a replacement."
Dec 07, 2012 | Panasonic TC-P46G10 Plasma TV
Sep 09, 2010 | 1995 Dodge Caravan
Jun 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
May 31, 2009 | Apple iPod shuffle Second Gen. Silver (1...
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Nov 20, 2008 | Televison & Video
Jul 07, 2008 | Apple iPod shuffle Second Gen. Silver (1...
May 23, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Apr 09, 2008 | Creative Labs ZEN V Plus MP3 Player
Sep 18, 2007 | Apple iPod shuffle Second Gen. Silver (1...
