Question about Bosch Ovens
Bosch HBL 500 series oven code E115 just came on and I was not trying to heat oven
Posted by Sandra Riggins on
5 Related Answers
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
Anonymous
  • 36 Answers
SOURCE: Bosch oven won't pre-heat/heat with door closed
hi ,
according to me ,there is some issue with the cables that are connected the heat functionality of oven , because the same happned with my lg microwave , then the tech checked it , it was a cable fault , one of the cable was loose when the door was fully closed microwave was not working but when we leave some space while closing it it was working , so it is recomended if your oven is in warranty the call the company technicans to fix it , plase dont try if dont have expertis on it take help of tech who knows about microwave
Posted on May 24, 2008
Anonymous
  • 491 Answers
SOURCE: Door Hinges for Bosch oven HBL 545
CONTACT BOSCH FOR INFORMATION
Posted on Jul 18, 2009
Anonymous
  • 491 Answers
SOURCE: Hi experts. I have a Bosch Oven Model: HBL 745 A
FIRST CHECK FOR ANY BURNT WIRES THEN REPLACE THE HEATING COIL AND TERMOSTATS AND YOUR OVEN SHOULDWORK FINE, BUT MAKE SURE YOU CHECK ALL WIRING FIRST.
Posted on Nov 08, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Posted on Jan 04, 2010
My Bosch oven will not heat
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 04, 2011 | Bosch HBL 445 Stainless Steel Electric...
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Tip
Common heating faults with Bosch HBL 442 / HBL 446 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
Tip
Common heating faults with Bosch HBL 742 / HBL 746 single oven
on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
Does not turn on
heatman101
Dec 10, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
700 series Bosch double convection ovens - Convection roast works, convection bake does not. Fast pre-heat does not work. We tried to reset ovens according to Bosch instruction manual guidelines, but it...
The good sign is that the motor works fine as do heaters. If the operator interface acknowledges feature selection by beeping or what have you, we can safely say the problem lies with the control board or relay.
Oct 02, 2009 | Bosch HBL 455 Stainless Steel Electric...
I have Bosch double oven HBL HBN and does not
sensors would not make it heat up any quicker element might be getting weak,but 10 mins to heat up is about normal.
Sep 27, 2009 | Ovens
Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Ovens Logo
170 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Paul Carew
Michael Thomas
Michael Thomas
Are you a Bosch Oven Expert? Answer questions, earn points and help others
