Question about Doro Cell Phones
Doro 70 60. It's charged and being switched on properly. Why doesn't it turn on?
Posted by una gallagher on
Doro 5030 phone fully charged won't turn on
Go to nearby Phone technician to fix that problems. The phone may encounter setting corruption or the LCD damage.
May 13, 2017 | Doro Cell Phones
Doro 410S. I removed the battery so I could check serial number. Replaced battery and now it will not switch on. Battery is fully charged, Please help.
Remove the battery and clean the battery contacts with methylated spirits and the battery contacts in the cell phone.Make sure the battery is inserted correctly with the camera contacts.
Feb 01, 2013 | Doro PhoneEasy 410 Cell Phone
Doro 410 mobile phone. Just bought today - screen blank.
Some phone needs batteries in it or a power supply plugged into it if both are good the return phone it defective
Jan 18, 2010 | Doro Phone Easy
Doro 5065R +3 not working after replaced battery
I have replace my doro batteries with Duracell rechargeables, just make sure you fully charge them before you put them in the handset.  If you find after a time that the charge goes again, charge them again (in the charger you buy when you buy the batteries)! Hope this helps.  PS, do you know how to turn the answering machine on?
May 06, 2008 | Doro 730R Cordless Phone
Doro 133R phone - answering machine not working
a bit late for this persons problem, but if anyone needs a manual here's the doro site - just type in the model number and you will be able to download the pdf.... http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
Jan 19, 2008 | Doro 830R Cordless Phone
Doro 130 R
Go to http://www.doro.com.au select home phones then Support then Manuals Then you type in your model which should be on the back of the base unit.
Oct 28, 2007 | Doro 530 Twin Cordless Phone
Cell Phones Logo
198 people viewed this question
Top Doro Cell Phones Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Doro Cell Phone Expert? Answer questions, earn points and help others
