SOURCE: Wurlitzer 1800 jukebox, plays record
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Posted on Jun 25, 2009
SOURCE: dual 1218
What happens if you lift the tonearm and slowly move it over its travel in toward the label area past the expected point at which it should cycle? There should be a mechanical click as it engages the lift / return cycle. If so, the mechanism works but might be out of adjustment due to wear and tear.
Perhaps cycling the Record Size switch a few times might have a positive effect on the function. There doesn't seem to be a user adjustment for the end of play cycle.
You can get the manual for free after you register at:
http://www.vinylengine.com/library/dual/1218.shtml
If you decide to venture into the mechanics be cautious, always protect the tonearm from damage and make sure you rotate the platter only clockwise as there are mechanical interlocks that could get damaged if you turn it the wrong way.
Posted on Mar 10, 2010
SOURCE: Pertaining to the Wurlitzer 2600
last one i repaired for someone i had a similar problem ,but it was with a 1970 rockola ,anyway i screamed where do i get parts went away and had a cup of tea ,well i am british after all .Then i got a plastic tie out of old junk box and used this as a spacer ,its still working 2 yrs later in a bar local to here as a museum piece with old 60s records on and they use it on live music nights .
Posted on Sep 03, 2010
Hi Richard, at the base of the tonearm look for a rubber grommet. Under it you will find a screw. Adjust clockwise slightly to make the tonearm lift further along. Fine tune antil sorted. If the adjustment is not at tonearm base remove the rubber platter mat. If the platter has an access hole in it rotate platter so the hole is near the tonearm and look for scew to adjust. John styluscity.com
Posted on Nov 30, 2011
SOURCE: The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Posted on Jul 01, 2016
Jan 19, 2017 | The Audio Players & Recorders
Aug 17, 2014 | Audio Players & Recorders
Dec 09, 2012 | Audio Players & Recorders
Aug 27, 2012 | Audio Players & Recorders
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Mar 14, 2010 | Audio Players & Recorders
Feb 10, 2010 | Audio Players & Recorders
Oct 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Apr 14, 2009 | Teac AG-V1050 Receiver
Jun 09, 2008 | Audio Players & Recorders
