Question about Dynex Televison & Video
Dynex with no remote. Buttons stick. Can't get channel search. Or out of foreign language!
Posted by Cassie Morris on
David Spradling
    Top Expert:
  • Dynex Master
  • 11,320 Answers
Try RCA universal remote
Posted on Nov 05, 2019
5 Related Answers
Anonymous
SOURCE: setup
ugkghkg
Posted on May 09, 2008
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: Channel 100 and above on remote
100 + enter
that is the TV is programmed over 100 channels.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
Anonymous
  • 3 Answers
SOURCE: need code for Dynex/DX-l42-10A for Dish Network
I know you've probably figured this out by now, since you posted last May, but I figured I would post the solution, since I just found it, and someone else may want to know.
I bought one of these sets the day after Christmas 2009, and finally figured out the code that works with the Dish Network 5.4 IR remote.
I did a Code Scan, and found that the code that works is 721. In the Dish Network listing, this is listed as the third code for Sansui.
Hope someone finds this useful, even if it's too late for you.
Posted on Feb 23, 2010
jdvillanueva
Jdvillanueva
  • 2098 Answers
SOURCE: my dynex 26 in tv
If the unit is stock on highest volume and one channel only, the tact switch must be check, open the back cover, pull-out the board and spray an electrical contact cleaner into this switch while pushing on and off to clean its internal contact. You may also replace it all, it will not cost you much because it is one of the cheapest parts on the board.
Let me know if the symptoms still persist after the above solution had been done.
Jdvillanueva
Posted on Jun 23, 2011
electron-man
dan
  • 136 Answers
SOURCE: I have a 32 in
possible bad back light inverter board or broken back light tube. refer to local service tech
Posted on Aug 24, 2011
Lost the remote for my Dynex and trying to connect to cable. Without the remote I cannot seem to change to chanel 3 manually, any suggestions?
Most TVs have a way of changing the channels manually. One of the buttons on the device will change the channels up or down.
May 24, 2017 | Dynex Televison & Video
HOW DO I CHANGE LANGUAGE WITH MY DYNEX REMOTE
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 25, 2017 | Dynex Televison & Video
I want to change languag to english
Pl. select menu option with remote,search for language option with the help of channel and volume plus and minus buttons,open the option find the list of language,select the required language,come out of menu by pressing menu button.
Jan 15, 2011 | Televison & Video
Switch the tv to video without the remote
On some Dynex TVs, there are control buttons on the side of the TV (Volume controls, Channel controls, Menu, Input and Power). Just press the Input button until you get to the correct source.
http://www.dynexproducts.com/products/televisions.html#support=open&active=false&pageNumber=1&subcategoryId=31-to-40&resultsPerPage=all
will let you find your model and get a copy of the manual to check where those buttons are on your TV.
I hope this helps.
May 08, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
When I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
Sep 28, 2009 | Televison & Video
Dynex 19" tv
Go into the setup screen on the TV and set the channel option to CABLE (it is probably set to AIR right now or something).
The website should also have a manual for how to program the remote.
Sep 08, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Setup
First , look for a manual switch front or back....then figure how to
add / subtract channels in memory / set-up....that may allow for
AV1 AV2 to be added...usually between 99 and 02............T.
Mar 10, 2008 | Televison & Video
Televison & Video Logo
54 people viewed this question
Top Dynex Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
