Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows explorer. How do I initialize?
Posted by schroete584 on
Anonymous
  • 4 Answers
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Posted on Sep 14, 2009
Lacie d2 Quatra 500 BG ext drive Windows XP won't mount. light blinks sounds like it's cycling inside. Any solutions? Need new driver?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Sep 16, 2011 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I am trying to set up the LaCie d2 quadra. I follow the steps in the manual but nothing is loading to My Computer.
you will need to go in Disk Management and format the drive first then it will be available in My Computer.
Regards,
Dec 30, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB was formatted for MAC and given for use on PC. It does not show up anywhere when plugged in, blue light on. pc says device detected, but does not recognize and it does not show up in control...
You will need to format the device for Windows use. If you can see the device in My Computer, right click it and select format. if you can't see it in My Computer, you will need to use a boot tool such as Gparted: http://gparted.sourceforge.net/download.php
Download the .iso file and burn it as an image to a cd, then boot from the CD at startup. It should detect the 500 Gb drive and allow you to format it to NTFS. Then Windows will recognize it.
Mar 09, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Drive not showing up on my desktop
i'm not sure i can solve this problem--which started for me tonight as well with my lacie d2 quadra 500 gb--but i can share a possible explanation i've found online: apparently, they have lots of problems with their power supplies. see if the power adapter (the black brick) is making a hissing sound, or if there is a ticking sound coming from the drive itself. i have both these sounds. i am hoping all my data is safe and that my i.t dept. will be able to fix it with a new power supply on monday.
Sep 21, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
343 people viewed this question
Top LaCie Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
