Question about Panasonic Audio Players & Recorders
Remote codes for panasonic SA-HT70 - Panasonic Audio Players & Recorders
Tom Chichester
    Top Expert:
  • Panasonic Master
  • 58,368 Answers
Applicable codes will be found in the remote control, if it is compatible.
Posted on Sep 15, 2019
5 Related Answers
devocap
Devocap
  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
Posted on Jan 28, 2008
Anonymous
SOURCE: PANASONIC SA-HT70 DVD PLAYER READS
Débranche du secteur et rebranche = OK !
Posted on Mar 16, 2008
Anonymous
  • 298 Answers
SOURCE: Panasonic SA-HE100 Remote
The correct replacement remote from Panasonic can be found in the link below.
Panasonic SA-HE100 Replacement Remote
Posted on Jun 25, 2008
ravichetty
RAVI CHETTY
  • 158 Answers
SOURCE: Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
Posted on Jul 31, 2009
Anonymous
SOURCE: can't play iPod on my panasonic sa-en27 with out a remote
I ran into the same issue, instead of buying a replacement remote I was able to dial in a Vip 211 dish network remote control with remote code 643 in AUX setting. Then once the code was in, i pressed the 6 key on the remote and now I can listen to audio on the music port. The 643 code refers to the first Panasonic amplifier/receiver in the code list. To further clarify, I pressed AUX for 4 seconds, pressed 2 to signal I am programming an amplifier/receiver device, then punched in 643 then pound sign.
Good luck with yours.
Posted on Jun 18, 2010
Subwoofer channel no longer has output
Is your sub powered (amplifier built-in)? If so, connect your MP3 player directly to the sub input and see if you hear audio. If you do hear audio, check for cable problems from Panasonic to sub input. If the sub is unpowered then it's either the speaker wiring, an intermittent sub and/or your Panasonic at fault.
Mar 22, 2015 | Panasonic Sa-ht70 Home Theater Receiver 5...
I need a remote for as-ht70home theatre
Here is one on the Bay
PANASONIC Remote Control for SC HT70 SC HT65 SA HT70 SA HT65 Free Shipping
Couldn't find factory new available. Best bet may be a universal.
Jan 06, 2015 | Audio Players & Recorders
Panasonic sa-vk800 when the volume up the unit is shoot down than display f16
Check all of your speaker wire connections at both ends for looseness, strand wire fraying/breakage, correct polarity and corrosion. If all are ok, reduce your setting for the amount of bass it outputs.
Dec 15, 2014 | Panasonic Sa-ht70 Home Theater Receiver 5...
Can Panasonic saht70 play blueray disc
1) you must get the support via ONLINE chat from the manufacturer to see if possible to play blue ray disc 2) the same way get the manufacturer some schem how to connect the speaker without the player.
God bless you
Nov 25, 2013 | Panasonic Sa-ht70 Home Theater Receiver 5...
Panasonic sa ht70 surround sound instructions
I just tried this with another set of speakers and unfortunately since the iPad does not have left center or right speaker gain you will have to settle for the sound from one side level. unless you can figure out a way to splice all the speaker's configuration to a audio jack then you will have to settle for ear phone sound quality.
Nov 25, 2013 | Audio Players & Recorders
I need to reprogram the remote. Purchased a floor model Panasonic SC-PT480 and the remote is not fully synched with the player (controls on/off and volume only). How can I reprogram the remote?
The remote cannot be reprogrammed to operate the SC-HT70 as all functions are already set. If your remote isn't operating your equipment as expected then the chances are the remote has become faulty.
The remote can be programmed to operate other equipment as detailed on Page 42 of the manual below.
http://service.us.panasonic.com/OPERMANPDF/SCHT70.PDF
May 01, 2011 | Panasonic SC-HT70 System
I have skandia universal remote and need code for soniq 42in plasma tv
I have a BASE DV-4304 DVD Player and i need the code for my Skandia Universal Remote. Please Help.
Dec 31, 2009 | Televison & Video
My panasonic sa ht7o plays dvds fine but no
you have it hooked up as a component with one of the three video cables crossed
Aug 24, 2009 | Audio Players & Recorders
My sa-ht70 wont go above 0db on the volume control,it used to but wont now. Any help?
Check and lower the speaker levels. Then see what the max is on the volume control.
Mar 01, 2009 | Panasonic SC-HT70 System
Hack code for Panasonic SC HT70
go here
http://www.videohelp.com/dvdhacks/panasonic-sc-ht70/729
Oct 27, 2007 | Panasonic SC-HT70 System
67 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
