Question about Vehicle Parts & Accessories
My pace edward tonneau cover will not retracted all the way
Posted by John Rice on
Jim R
Get some super lube. pull the cover all the way out and lube the mechinsum
Posted on Sep 20, 2019
1 Related Answer
Anonymous
SOURCE: Tonneau cover
one side of mine wouldnt unlock i sprayed it with like a wd40 then if still wouldnt come off i removed it from the top and let the bar hang inside the truck then took a pair of pliers and gently pulled up on the release and without the cover bein still attached it had no pressure and came off a little easier
Posted on Jan 24, 2009
Pace Edwards tonneau cover will not open
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Jun 17, 2018 | Cars & Trucks
Bedlocker won't open
I read on another forum where they had a problem with some of their Brake Mechanisms failing.
"Easy fix. Just take 3 screws out from the side of the motor and the unit comes right off. The brake is added so that the bedlocker stays locked in-place once the pressure sensor shuts off the motor. Without it, the cover may activate with vibration of the moving vehicle."
You could also contact Pace Edwards at
http://www.pace-edwards.com/site/?d=123&dt=36
& see what help they could offer.
Apr 22, 2014 | BL2028: BedLocker Tonneau Canisters
Tonneau cover broken rewind
there is no alternative but for you to rewind the cover by hand and then get the spring mechanism repaired /replaced .
Apr 19, 2014 | 2004 Hyundai Santa Fe
Chevy idle problems
Biggest problem that I have found with these motors concerning idle is a dirty throttle body plate. Get some carb cleaner open the butterfly, spray it grab a rag and clean out as much of the black residue you can. Don't spray to much Down intake. May backfire. You can spray the rag down and work it back and forth. Hope this helps
Nov 15, 2013 | 1997-2000 Chevy Colorado Utility Rig Rack...
Tonneau cover
I've seen a lot of <a href="http://www.hitchcity.com/CapsCovers-Covers.html">tonneau covers in Toronto</a> just be removed and re-installed and that usually takes care of any problem. Try it out.
May 10, 2013 | 1999 BMW 328 Series
I have installed a pace Edwards jack rabbit roll up toneau cover on a 07 tundra. The mounting clamps are attached at the front of the rail near the canister and about 8" from the tailgate. The problem...
As you may be aware, the knob has to be rotated to pull in the latches so you can open the top. When you pull on the strap to close the top, I releases the latches so they will stop at the 1 ft intervals.
1. Make sure that when you pull on the strap, you see the knob pop back to the lock position (handle going side to side) If it stays in a front to back orientation, the strap is not pulling on the latch release.
2. On either side of the roll top, there is a plastic block that keeps the latch bars in place. If one of the screws falls out, you will lose control of the latch on that side so it no longer locks the cover at any of the intervals.
I've had a jackrabbit cover for the past 8 years and I've only had a couple little issues related to the latching. The things i indicated are what I found to be the problem at different times.
Nov 25, 2010 | Edwards Furniture Pace Edwards Roll Top...
Vehicle Parts & Accessories Logo
157 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
