Question about Sharp Aquos Televison & Video
It's a new sharp aquos 42inch tv and I want to install if i enter new installation then It's write input password
Posted by Thomas annor on
ray gallant
    Top Expert:
  • Sharp Master
  • 69,253 Answers
PUT NOTHING IN THEN HIT ENTER
Posted on Nov 05, 2019
5 Related Answers
Eduard P
  • 71 Answers
SOURCE: Sharp Aquos Color Variations
Put the OPC off and check the conection for Pb signal.
Posted on Dec 06, 2007
Anonymous
  • 53 Answers
SOURCE: My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Posted on Mar 14, 2008
Chi Chu
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
HeadnSouth
  • 18 Answers
SOURCE: incompatible video signal has been recieved
I just had the same problem and it turned out to be the HDMI cable.
Posted on Oct 15, 2010
Anonymous
  • 4 Answers
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Posted on Nov 27, 2010
The demo mode apears every 30 minutes. I can't really stand it. How can I shut it doen for ever? Sharp aquos LED 40"
I'm not certain of the specific model number of your set, but this should be the same for all Sharp Aquos models.
First, navigate to TV input, and select menu
Next, enter setup and select, "ez setup"
In the ez setup menu, select "home", not "store", for television location.
This should turn off the demo mode and solve your issue.
Jun 10, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sharp aquos no sound through hdmi
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
Lc-32pd5x its a roof mount antenna not sure what brand it works fine on my other lcd
so you could not wait 1 minute while I wrote to you how to reset it?
by default from factory the pin code is 1234
heres the full user manual for your tv
http://www.cleverhome.com.au/user/Sharp-Aquos-Piano-Black-LC37PD5X-LC32PD5X-manual.pdf
if the code doesn't work heres how to reset the tv
HOW TO SET THE FACTORY PRESETS
Turn off the TV by pressing POWER on the TV.
After waiting for about 1 minute, press and hold down RESET and press POWER on the TV to turn on the
TV.
All setting items (except TV channel) return to the factory presetting.
note Password will be cleared after running the factory presetting operation.
You can run the Auto Installation again by using the following steps.
1 Turn on the power of the TV.
2 Press MENU. (Make sure the menu screen displays.)
3 Press left or right to select “Setup”.
4 Press up or down to select “Auto Installation”, and then press ENTER.
5 Press left or right to select “Yes”, and then press ENTER.
Jun 17, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Dec 23, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
67 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
