Unselect skip channel
My analog channels are checked skip how to change this
Posted by Sarah Walker on
David Spradling
    Top Expert:
  • Televison & ... Master
  • 11,347 Answers
Re channel select
Posted on Sep 15, 2019
5 Related Answers
Anonymous
SOURCE: Skipped channel 4
I have the EWF2004 emerson TV. I tried a ONE For all universal remote and programmed it for a FUNAI TV code 0179 and it worked!!!!!!
Posted on Oct 05, 2008
Jim Franks
  • 374 Answers
SOURCE: Channels are skipping
Turn the power off to the receiver and let it run its course. It should download a new program guide at this time. Another thing is to make sure you are on ALL SUB on the guide as opposed to a favorite self created guide.Thanks for using Fix Ya.
Posted on Mar 16, 2009
Anonymous
  • 3 Answers
SOURCE: Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Posted on May 18, 2009
Anonymous
SOURCE: Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Posted on Jun 02, 2009
Anonymous
SOURCE: Trying to scan channels into my vizio, but no
I called my satellite provider. Problem solved!
Posted on Jul 07, 2009
LC-26DV24U-trying to scan for new analog channels
Check that the current input is TV. Press the Input button on the TV or the remote. If it isn't, press Input several times or use the Up/Down arrows. Once TV is highlighted, then either wait or press Enter to go to that source. Now try to access the Channels sub-menu.
I hope this helps. The manual for the Sharp LC-26DV24U is available at Sears Parts Direct: https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0810455.pdf .
(It's normal for most TVs to skip parts of the On-screen menu when the source isn't compatible with the options in that section. Note: if you are using a universal remote, even if there is a source/input button, you may need to try multiple codes for the Sharp brand to ensure that the Input/Source button works. The On/Off code is usually going to work with several codes.)
Jul 23, 2018 | Televison & Video
Channel cable hdmi
You will need to go into the tv's "settings" menu and change the input label from "Skip" to anything else that best describes the device that is attached to it.
Good Luck!!
Rich Lilja
Dec 24, 2013 | Sony BRAVIA KDL-23S2000 23" LCD TV
How do you delete unwanted digital channels we have lost our instructions for panasonic viera TH-42 PX7A
Go to Setup, Tuning Menu, Analog Program Edit, Select the Channel to Edit and set it to skip the channels you don't want to see anymore.
Mar 01, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Aug 22, 2009 | Televison & Video
Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
May 02, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
biigg53566
Feb 19, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
