I have done everything I can think of including a factory reset and still no sound.
SOURCE: No sound on my toshiba television
Go to the setup menu and turn the TV speakers back on.
Posted on Feb 16, 2008
SOURCE: I have sound and no picture
These unit will mute the video for a number of reasons. F889, F890, F891, F850, F470 one of these fuses is open then fine out what caused the fuse to open. This an older unit so parts may be hard to find. The cost to repair it should not be to bad.
Posted on May 14, 2009
SOURCE: Here is the make and model number of my television
TV could be as old as 12yrs old or older
Posted on Dec 01, 2009
SOURCE: I have a 1994 Toshiba Television. It was working
I usually do not give a one line suggestion but if you lost sound after moving it--look on the back to see if there is a slide switch--some models have this to select if internal or external speakers are being used.
It may have got moved when the set was moved. A few also have it on the front of the set.
If not this, the circuit board inside either got damaged or the speaker leads dislodged.
let me know what you find.
If this helped, rate this solution as I do this here for free.
Regards, SD TECH
Posted on Dec 19, 2009
