Question about Disney Watches
How to set a Disney Time Works watch which is analog and digital with 3 buttons and a analog stem also. 1980's vintage
Posted by Gerald Carroll on
5 Related Answers
Anonymous
SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Posted on Sep 27, 2007
Anonymous
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Posted on Apr 11, 2008
Ekse
  • 13434 Answers
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
saturnd00d
  • 5 Answers
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Posted on Dec 20, 2008
Anonymous
SOURCE: How do I set the digital time on a mossimo
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Posted on Apr 20, 2009
How to set day on non digital george watch
I'm not familiar with the George watch but analog (non-digital) watches typically have a stem with which you set the time and the day. On most watches the stem has two clicks when you pull it out (gently). The first clich should set the day by rotating the stem counter-clockwise while the second click sets the time. On wind-up watches this stem also winds the watch when not pulled out.
May 01, 2011 | Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
Today is Tuesday, March 8. My Caravelle by Bulova watch says it is Wed March 10. How do I get this corrected since the only manual that came with the watch doesn't tell me anything. My watch is a square...
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
Mar 08, 2011 | Caravell Bulova Caravelle watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
New battery inserted.digital part of watch shows correct time.clockfave shows different time.also the 2 buttons on the side when pressed in do not come out again
First, take the back off the watch and make sure that the movement is inserted correctly. When buttons dont come back out it is usually the movement in the case wrong or the back is put back on wrong. If it is a pop off back then you want to be sure the dimples in the back are over the stem and crown and buttons so they move freely. Also, be sure that any springs that were in place are still in place.
Now i dont know what brand or model of watch this is but most digital analogs have a stem and crown to set the analog. Pull out the stem to the first position and set the time.
For specific instructions please leave the brand and model.
Thanks!
Sep 19, 2009 | Watches
Cannot get watch hands to sync with the digital time. mine is movement ''c320'' older watch, citizen ''navisail'' stars and stripes 2000 special edition....america's cup watch.
pull stem out and push all other buttons a b c at same time to reboot next step advance hands min/hour/sec to 12:00 push in stem M and start your reset
May 09, 2009 | Citizen Watches
Can't set the hour on my Aqualand Duplex
i followed the instructions on the Citizen website for a system reset and it worked. Unfortunately, the regular way of setting the digital hour does not. Maybe a technical problem? The movement number for the Aqualand duplex is C506.
1. unscrew the analog adjustment crown and pull one click
2. press and hold the other 3 buttons for 3 seconds and release.
3. push the analog crown back and adjust the digital time.
this is a system reset so you will have to set the date. You will lose your settings and your dives. good luck.
Mar 10, 2008 | Citizen Aqualand Duplex JP104009E Wrist...
Watches Logo
168 people viewed this question
Top Disney Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
George Scott
George Scott
Are you a Disney Watch Expert? Answer questions, earn points and help others
