Dryers Logo
j
janice Posted on Sep 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore elite dryer whistles when the heat element engages
Tony Marley
Level 2:
Habit-Forming:
New Friend:
  • Expert 87 Answers
  • Posted on Sep 14, 2019
Tony Marley
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
87
Questions
Helped
50826
Points
212
Not knowing anything about your dryer, such as model number or age and when the last time it was given a good tune up. I would say that the pulley that works as a belt tensioner needs to be replaced. My best suggestion would be to give your dryer a good tune up which includes replacing all the rollers and pulley, the belt and a good cleaning. This would probably cure your noise and it would also reduce the chance of a dryer fire.
I hope this helps
5 Related Answers
Anonymous
  • 1028 Answers
  • Posted on Jun 19, 2008
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Anonymous
  • 5911 Answers
  • Posted on Jun 12, 2009
SOURCE: Kenmore Elite He4 Dryer Model Number 110.85872400
Before assuming you have a bad heating element, read through the following link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Most dryer heat related problems are attributed to poor ventilation which, in turn, causes the dryer to overheat to the point of failure. More commonly the Thermal Cut-Out (TCO) fails. The component acts as a fuse and must be replaced if bad. In addition, if the TCO is determined to be defective, it is recommended that you replace the Hi-Limit Thermostat at the same time. Both these components work in conjunction with the heating element and are mounted on the heater box. The TCO is located on the end opposite the heating element terminals. The Hi-Limit Thermostat is located adjacent to the heating element leads. These two components are often sold as a kit. If you fail to replace both of them you can experience premature failure of the component you do replace.
Pay particular attention to the section that discusses proper dryer ventilation. If you haven't checked or cleaned the exhaust ducting any time recently, now might be a good time to do so . A dryer left in a clogged or poorly ventilated condition will cause repeated failures in the heating circuit. Not to mention this creates a fire hazard.
If you read through the link and determine that you have a bad heating element, follow these steps to remove:
1. Unplug the dryer and remove the lower panel under the door.
2. Remove the lint screen from the dryer door.
3. Remove the blower fan housing vent cover.
4. Disconnect and label the component wiring on the heater box.
5. Loosen the mounting screw on the heater box front support.
6. The entire heater box, with element inside, should slide out of the dryer.
7. There should be a couple of mounting screws on the component side of the heater box that you need to remove and the entire element slides out.
If you still have questions, please let me know. I hope this helps you.
Anonymous
  • 135 Answers
  • Posted on Aug 27, 2009
SOURCE: Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Testimonial: "I replaced both works great thanks for the conformation."
Anonymous
  • 5911 Answers
  • Posted on Jan 06, 2010
SOURCE: How do you replace the heating element on kenmore
Have you confirmed the heating element is bad? There's more to the dryer heating circuits that can cause a no heat problem besides the heating element.
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare.
Now...if you have determined the heating element is definitely bad, and this is a Kenmore Elite as the one you posted this question under, the following link explains how to access the heating element and replace it: http://www.fixya.com/support/r3677025-elite_duet_dryer_heating_element If you need further assistance, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Anonymous
  • 1606 Answers
  • Posted on Apr 28, 2010
SOURCE: kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
My dryer kenmore elite 11074972300 doesn't heat
I had this problem with one of my dryers and it turned out that the heating element was broken. It is a repair man that you need now I'm afraid.
Nov 04, 2012 • Dryers
Our Kenmore elite dryer has no heat, what do I do?
The First thing I would do is look at the heating element, you must unplug the dryer and remove the screwsfrom the back of the dryer and then locate the element and inspect it for being broke, if any of the coil of the element is broken you must order a new element.
Kenmore Elite 11063932102 is not working but no heat come out. What may be the problem?
is it coming on like it should but just is not heating if so it can b a number of things like a heat limit switch ,heat selector switch, heating element bad , a wire burnt off heating element or the switch on the motor (on some models)
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
2helpful
Kenmore elite elec dryer, 110.64972300. runs no heat
Heating problem with kenmore elite he4 electric dryer. drum turns, lent trap clean, heating element ohms ok, thermo coupler ohms ok, thermostat ohms ok, timer counting down. still no heat.
limit switch stuck open should be behind motor housing is a tight fit to get to but there are two there on the element one on vent tube the other is thermal switch recommend chang the two on the tube ck element limits should all read continuityif not reolace
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
2helpful
Kenmore elite electric dryer want heat
chances are the element is broken. generally the element will eventually break at a weak point. if you are a "fix it yourself" type you can repair the element with a little efort. (be glad to tell you how if t you choose this as apposed buying a new one.
good luck.......jay
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
