Question about Bernina Sewing Machines
My Bernina 830e isn't making a stitch. - Bernina Sewing Machines
Posted by Kathryn Marshall on
5 Related Answers
elizebeth900
  • 13 Answers
SOURCE: old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Posted on Aug 29, 2009
relicssmm
  • 20 Answers
SOURCE: Bernina 1080 while sewing normal stitch, stitch
What stitch to you have selected for it to do? Please check to see if it is set for straight stitch only.
Linda at Relics
www.sewing-machine-manuals.com
Posted on Jul 05, 2011
SOURCE: I have a 30 yr old Bernina 830E and all of a sudden it won't zig-zag. All is set to specifications in the manual.
it sounds like it needs to be serviced, to find out the problem
Posted on Jan 20, 2012
SOURCE: bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Posted on Apr 29, 2012
SOURCE: my surger isn't making stitches
what is the name & model number of the machine?
do you have a manual?
try changing the needles
Posted on May 03, 2012
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
I have an 820. The needle threader is clean of lint but still does not work
Threading the BERNINA 880e 830e 820 Bernina Sewing Center Tampa
http://www.manualslib.com/manual/726261/Bernina-820.html?page=30
Bernina 830 880 Needle Threader Cleaning
Install a brand new needle. Verify that it is installed correctly and is facing straight forward. If it is still not threading properly, then something may be bent or out of place in the threader.
May 15, 2016 | Bernina Sewing Machines
How do I clear cotton in bobbin case of Bernina 830E
take the needle out of the needle holder
remove the needle plate, be careful not to damage the screws
take the bobbin out and use a small brush or a can of computer air to clean dust, use a pair of tweezers to pull the thread of the bobbin area if needed
Apr 16, 2015 | Bernina Sewing Machines
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
May 14, 2010 | Bernina Bernette 75
Bernina 240, won't complete the buttonhole
Double check the instructions and if there is still an issue, call the Bernina dealer and tell them what is wrong.
Ask if someone will be available to look at the machine when you come in .... you need one-on-one assistance.
Mar 07, 2010 | Bernina Sewing Machines
Sewing Machines Logo
108 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
