Question about Amana Refrigerators
My Amana asd2624hen freezer is not freezing - Amana Refrigerators
Posted by Hjrs on
Matt Vierra
    Scholar:
  • 75 Answers
Check first that there is no leak coming through your gasket a good way is stick a flashlight inside your freezer turn out the lights if you see and beam or light the seal is cracked or must be replaced the check your coils where Freon is supplied if there not cold you must to a pressure test while adding Freon also check for leaks by spraying water on your coils . It's a matter of mathematical elimination also check thermostat if your Amana is under 10 years old look for the fault codes and get someone that can read what faults are being detected
Posted on Sep 13, 2019
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Amana fridge is not cold
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 26, 2011 | Amana ABB1927DE Bottom Freezer...
My amana refrigerator is not cooling, freezer is working
Oct 22, 2011 | Amana ARB2217CSR Bottom Freezer...
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Aug 26, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Feb 08, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
105 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
