Question about Irons
Red light flashing on the phillips stem iron - Irons
Posted by Nicki Williams-Gray on
jasagoli duniabaru
Indicator
Posted on Sep 14, 2019
Get the red light off, no heat and so no steam.
check main wire or main plug of wire
Dec 22, 2014 | Irons
Not heating up, flashing light
It sounds like you have a loose wire, check your plug to make sure the wire connections are sound. The loose connection may be where the wire enters the iron its self. For saftey I would have this repaired by a professional or have it replaced.
Dec 04, 2009 | Tefal Irons
Iron will not heat up and the auto off red light keeps flashing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 07, 2009 | Philips HI-296 Iron
It gets hot but there is no steam or noise from it also the red standby button is flashing
i have a tesco steam generator iron, model no. sgc2 it has no steam or noise but red stand by light is flashing
Jul 11, 2009 | Irons
Autoshut off red light keeps flashing
I had the same problem and eventually removed the tilt sensor. This is the molded board that you see when you open the back of the iron. By removing it, you will also loose the timer off function. The thermostat will still be operational.
Oct 14, 2008 | Braun SI6285 Iron
Rowenta autosteam iron dz 1700 r
The electronic device is faulty and need to change inorder for the iron to work properly.
Regards
alan
Feb 23, 2008 | Irons
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
B&D AS 150 is not heating up
It's dead the elements inside are now gone. Spend $150.00 on a Phillips gold based iron. You will be very happy with it
Oct 29, 2007 | Micro Pro 7599 Iron
Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Irons Logo
143 people viewed this question
Top Irons Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Iron Expert? Answer questions, earn points and help others
