Question about JVC Computers & Internet
Can you maybe fix my JVC STEREO KEYBOARD - KB 300? The middle C is not working
Posted by Joan Lourens on
Larry Ng
  • JVC Master
  • 5,969 Answers
Clean the switches, 99% chance fixed.
use plastic safe electronics cleaner spray.
Posted on Sep 15, 2019
4 Related Answers
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Peavey KB 300 amp problems
Hi there.
You have have been unfortunate enough to experience an uncommon failure. The bass driver has failed. It is a Black Widow that can have the basket/cone/voice coil assembly replaced as a complete unit. The magnet unbolts from the basket and you bolt on a new one. Classic field service designed product. You will be able to get a new basket from a Peavey equipment stockist. Just ask for a 15' Black Widow replacement basket They cost about $180 here in Australia and you can easily change it yourself. Good Luck and happy jamming.
A FixYa rating would be great for my tech tip to you. Cheers
regards
Graeme
Posted on Mar 08, 2008
ABRsvcs
  • 4234 Answers
Yes a horn can get blown. This should be 2 pieces, the horn itself and a circular driver on the rear. The driver itself will have what is called a diaphragm that can be removed and replaced. That is the part you want. Open up the speaker and get the part number off of the back of the horn and order the diaphragm from Peavey.
Dan
Posted on Aug 29, 2008
Ray M.
  • 215 Answers
SOURCE: AE 740 types different characters than typed on keyboard
make sure your printwheel is latched securely, turn off t/w, press and hold the margin release button while turning power on to do a reset/self-test. if characters are not right on self test, then you might have a problem with either the carriage or main board.
hth,
razors
Posted on Feb 27, 2009
Spud Howell
  • 66 Answers
SOURCE: Where can I find a Peavey KB 300 Keyboard amp user
Have you tried Peaveys website? Usually you can find manuals there. I think you can print them for free ,but I'm not sure
Posted on Jun 12, 2009
Some keyboard letters stopped working. Can they be fixed?
NO it cant be fixed. But you can try to open the keyboard and take out the dust.
Oct 04, 2014 | Gateway Kb-0817 Keyboard Kb Black Us Ps/2
Have a jvc kd-sc401 connected 10 disc multichanger but won,t load cd,s although you can hear multi changer trying to work pls help.stereo working as should don,t have manual for stereo so don,t know how to...
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
About the User Manual, visit the next link to download: kdsc401-402e_get0410-001c_fr (pdf)
Hope this helps.
Sep 27, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have a JVC (stereo, radio, cassette, recorder) and it's buzzing
If it is only when the tape is running, it could be motor noise.
Worn bearing in the motor or maybe a suppressor has failed, if it has one.
Oct 09, 2017 | JVC RC-EX25 Radio/Cassette/CD Boombox
Need help replacing keyboard of acer 5536
I found them on ebay in 2 seconds. Ebay usually will have whatever you need. I'm sorry to say that this may not be a fix though. Most likely yes, but possibly not. What exactly is your keyboard doing? You should also know that even though your computer is functioning now, if you do not get the spillage cleaned off the motherboard it will cause the board and whatever components it got on to corrode. It's possible that it may not have gotten into you computer but I doubt it. How bad was the spill? It is also possible, depending on what the keyboard is doing exactly, that you may not need a new KB. It maybe just a good cleaning or cleaning out the KB connector.
Feb 08, 2010 | Acer Aspire 5536-5224 Notebook
I have a JVC KD-S32 car stereo and can't get the time to work.
hold down the sel button in the middle of the volume button and use the button that you use to go to the next track to scroll through the menu and you will find it
Jun 09, 2009 | JVC Everio GZ-MG130 Camcorder
JVC car stereo doesn't power up
Check the ground wire. It might have come loose. Ground wire is the only black wire in the harness.
Mar 12, 2009 | JVC Car Audio & Video
JVC Stereo won't open cd tray
Maybe something's jamming it, try fixing the drive, so it comes out.
Mar 16, 2008 | JVC MX-KB30 CD Shelf System
No manual with EL-KB-03-SV
Cool. The middle light is for the Caps Lock.
Nov 11, 2007 | Sunbeam EL-KB-03-BK Black 107 Key...
Computers & Internet Logo
Top JVC Computers & Internet Experts
Marvin
Marvin
Davit Mamyan
Davit Mamyan
Jim Pattison
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
