Hi Michael Davis, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Michael Davis, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: SONY DAV - S880 compact AV system
Sony.com may have a pdf downloadable manual available on line.
The standard way to connect Audio from a Receiver to a TV is to send a signal from the Tape outputs (RED & WHITE) on receiver via RCA cable to a Aux input (RED & WHITE) on the TV. Likewise, sending a Video signal from a receiver to a TV, is via a Co-Axial RCA cable , using a Video Out (YELLOW) on the receiver to a Aux Video Input (YELLOW) on the TV. An S-Video cable can also be used (in leu of yellow RCA cable) if available on both Receiver & TV.
SOURCE: Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
SOURCE: instructions for how to program the sharper image universal remote
i need to program the remote to a Apex tv. lost the booklet
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
