Question about Car Audio & Video
Hi I've recently purchased some suzohapp sas-4 speakers and I noticed that there are two green spring clips and a red and black clips at the moment I'm using the red and black could anyone tell me what the two green clips are for please ? K
Posted by Kevinlee on
2answers
5 pin harness has the following wires on a Realistic radio cassette car player: 1. Red - Power 2. Black - Negative ground 3. Green - ? 4. Yellow - ? 5. White - ?
Hi Marc,
What you have is a "common ground" car stereo which means all speaker negatives will be chassis (earth) ground. The following is a common wiring diagram for vintage aftermarket car stereo.
Constant 12V / Memory Keep Alive - yellow
Accessory - red
Ground - black
Right front speaker(+) - green
Left front speaker(+) - white
Even though I am 99.9% positive this is correct, please use at your own risk as I cannot be responsible if you fry your unit.
Good Luck!
~Rich G.
2helpful
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
1helpful
Hi, I bought a house with some Niles HD 6 speakers and need to move them down the wall to install a new cabinet. I can't work out how to remove them from the wall to install them lower?
First remove the wire mesh grill with a curved pin or lever it out with a sharp kitchen knife. Then you will notice four black screws very close the groove into which the grill fits.Using a correct size + screwdriver unscrew all the four screw anticlockwise till you feel the whole speaker panel shake loose. Make sure somebody is holding the outer frame while you are doing it or it might suddenly fall. The are red and black spring clip connectors for the speaker wires. Disconnect them foe removing the speakers completely.
2answers
Hi, just wanted to know if there is a diagram for the head unit. the colours for the left & right speakers in a ve ute?
*Remove drivers side centre console panel
*You'll see a black plug on the "side" of the stereo, this is your speaker outputs and constant 12v+.
Dark Green - / Light Green + = Front Right Speaker
Grey - / Brown + = Front Left Speaker
Light Blue - / Dark Blue + = Rear Right Speaker
Yellow/Red - / Brown + = Rear Right Speaker
I have 2 8 ohm stereo speakers, old school nothing fancy, I want to put a much longer and heavier wire on them. How do I do this. I do not want to spice into the existing wire.
Hi I am vortash , The easiest way would be to fit a couple of speaker spring connectors onto the back of the speakers , you've seen the type a small hole and you lift the clip insert the wire and the clip springs down holding the wire secure available from any Radioshack or Maplins usually coloured red & black .. then you can fit any cable you like to them and even extend them at a later date if you wish ?. Regards vortash
3helpful
2answers
Im lookin fer the radio wiring diagram for my 1996 geo prizm because someone cut the standard clip for the stock radio out
Under the center console/dash you should has two connectors.
LARGER CONNECTOR
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C Right Front Speaker (-) Blue Gray w/ Black Stripe
D Left Front Speaker (-) Purple White w/ Black Stripe
E Ground Wire Black Black
F +12 Volt Ignition Wire Gray Red
G Power Antenna Wire 1 Blue (join wires 1 & 2
H Power Antenna Wire 2 together to this blue wire)
I Do Not Use
SMALLER CONNECTOR
J Right Rear Speaker (+) Red Purple
K Right Rear Speaker (-) White Purple w/ Black Stripe
L +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
M Left Rear Speaker (+) Black Green
N Left Rear Speaker (-) Yellow Green w/ Black Stripe
1helpful
Auto wiring diagram
Battery PINK (+) RADIO HARNESS
Accesory BROWN/RED (+) RADIO HARNESS
Ground BLACK/DARK GREEN (-) RADIO HARNESS
Illumination ORANGE/DARK BLUE (+) RADIO HARNESS
LF Speaker (+) LIGHT GREEN/RED
LF Speaker (-) LIGHT GREEN/DARK GREEN
RF Speaker (+) LIGHT BLUE/VIOLET
RF Speaker (-) LIGHT BLUE/BLACK
LR Speaker (+) WHITE/RED
LR Speaker (-) WHITE/BLACK
RR Speaker (+) TAN/VIOLET
RR Speaker (-) TAN/BLACK
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Color code radio wires 1990 ford truck F350 4 w/d
Battery GREEN/YELLOW (+) RADIO HARNESS
Accesory YELLOW/BLACK (+) RADIO HARNESS
Ground RED OR BLACK (-) RADIO HARNESS
Illumination BLUE/RED (+) RADIO HARNESS
LF Speaker (+) ORANGE/GREEN
LF Speaker (-) BLACK/WHITE
RF Speaker (+) WHITE/GREEN
RF Speaker (-) BLACK/WHITE
LR Speaker (+) PINK/GREEN
LR Speaker (-) PINK/BLUE
RR Speaker (+) PINK/BLUE
RR Speaker (-) GREEN/ORANGE
radio Security YES
Kia stereo in a ford ed
hi, first you are better off to purchase a conversion plug from a stereo outlet (so that you arn't cutting the standard plug off)
the colours should be
orange/pink = L/F Speaker
orange/black = L/F Speaker
grey/green = R/F speaker
grey/black = R/F speaker
pink/black = L/R speaker
pink/green = L/R speaker
blue/black = R/R speaker
blue/red= R/R speaker
blue/white = switched wire
black = earth
green/yellow = hot wire
these are ef but should be the same
happy motoring
1helpful
2answers
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Car Audio & Video Logo
Top Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
