Question about Husqvarna Sewing Machines
Husqvarna viking designer se check upper thread Message what do I need to do to fix this
Posted by Susan Heineman on
sewcrazyshan
    Problem Solver:
  • 19 Answers
Re thread the machine then touch the icon CLOSE IT. if it keeps happening perhaps you need to change the needle.
Posted on Oct 04, 2019
5 Related Answers
Anonymous
SOURCE: Husqvarna Viking Designer 1 Beeper
when i,m doing a machine embrody the thread will fray in the needle and spoil the whole design, i,m afaird to do anything on a piece to keep. what is the best thread to use
Posted on Feb 14, 2008
Anonymous
SOURCE: Husqvarna Viking Designer 1 problems using metallic thread
Try using a bigger needle
Posted on Aug 06, 2008
deborahcha
  • 371 Answers
SOURCE: Need Viking Husqvarna Designer 1 ESS Owner's Manual
Try ebay or contact your local authorized Husqvarna Viking dealer. You can find a dealer closest to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us/
Posted on Sep 24, 2009
Pamsquilt
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
deborahcha
  • 371 Answers
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Posted on Feb 13, 2010
My Husqvarna designer SE is not telling me bobbin is empty
Hello, Dene -
Go to this Husqvarna Viking Desinger SE Troubleshooting website:
http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_SE_Troubleshooting_EN.pdf
Scroll down Page 1 to the section with the heading "Bobbin Alarm Does Not Work? Follow the instructions there.
If those steps do not get your bobbin sensor back in working order, I suspect you will need to have the bobbin sensor repaired by an authorized Husqvarna Viking sewing machine repair service.
I suggest you contact the Husqvarna Viking sewing machine dealer nearest you and ask about authorized repair businesses.
You can also contact Husqvarna Viking directly:
Toll free 1.800.446.2333
Monday - Friday: 8:00 am - 4:00 pm CST
[email protected]
Jan 02, 2018 | Husqvarna Sewing Machines
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
Embroidery unit of Designer se
Sounds like cable has become disconnected inside machine or emb unit. Have it checked by authorized Viking Dealer. Check website http://www.husqvarnaviking.com/us for nearest Viking dealer.
Feb 14, 2014 | Husqvarna Designer I
Viking designer SE sewing and embroider machine -- Thread that has come out of the take-up lever
If this problem persists there is an upgrade on the take up lever that has a plastic clip that holds the thread in better. Check with your dealer.
Dec 31, 2013 | Husqvarna Viking 1
I have a Designer SE and today while sewing the 'check upper thread' message kept coming up. There was nothing wrong with the thread and I rethread it several times after the message came up. I cleaned...
It's probably the sensor in the upper thread tension unit. If you look where the thread comes to the bottom before looping back up to the take-up lever, there is a small point coming out that holds the thread downward as the takeup lever moves up and down. Take a brush and clean any lint/dust out of that area or it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 08, 2010 | Sewing Machines
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
Mc 5700 problem
Check for loose threads or fluff in upper tension unit and bobbin case tension gauged to 14g resistence. Otherwise, service time I'm afraid. Have it serviced by an authorized Husqvarna Viking Service Technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 07, 2008 | Husqvarna Rose
Sewing Machines Logo
182 people viewed this question
Top Husqvarna Sewing Machines Experts
Marvin
Marvin
Charles Tidwell
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
